Hi everyone,
I’m planning to test and demo the DGX Spark “Building and Deploying a Multi-Agent Chatbot” playbook on a single workstation, and I’d like to confirm realistic minimum and recommended hardware specs.
I’m referring to this playbook and models:
DGX Spark multi-agent chatbot playbook (GitHub:
dgx-spark-playbooks) -
Models:
gpt-oss-120BGGUF (~63 GB) -
DeepSeek Coder 6.7B (GGUF)
Qwen3-Embedding-4B
Use case
Purpose: Proof-of-concept / pilot + live demo at an exhibition
Concurrency: Effectively single-user or 1–2 users at a time (controlled, not a public web service)
Workload:
Multi-agent chat orchestration (supervisor + tools)
RAG over a few uploaded PDFs
Code-related queries via DeepSeek Coder
Latency requirement: “Human acceptable” for a demo (a few seconds initial latency is fine). I don’t need cloud-level throughput, just something that doesn’t feel broken.
Candidate workstation
I have access to an HP Z8 workstation with:
CPU: Dual Xeon (plenty of cores/threads)
GPU: NVIDIA RTX A5000 (Ampere, 24 GB VRAM)
System RAM: 128 GB
Storage: NVMe SSD (≥ 2 TB)
OS plan: Ubuntu 22.04 LTS + latest NVIDIA driver + Docker + NVIDIA Container Toolkit
My questions
Is RTX A5000 (24 GB VRAM) + 128 GB RAM realistically enough to run:
gpt-oss-120BGGUF (~63 GB), -
DeepSeek Coder 6.7B,
and Qwen3-Embedding-4B
inside the multi-agent chatbot stack for a single interactive user (or at most 1–2 users at a time) without everything crawling?
If yes, what kind of throughput / token rate / latency should I realistically expect on this class of GPU?
Rough ballpark is fine: e.g., “~X tokens/sec for 120B GGUF” or “expect ~Y seconds for a ~200-token reply”. -
Are there any recommended configuration tweaks for this hardware?
Quantization level for
gpt-oss-120B(Q4 vs Q5 vs others)? -
Suggested llama.cpp parameters (GPU layers, batch size, threads) on a 24 GB card?
Limits on context length or max tokens to avoid thrashing RAM / swap?
If VRAM is not sufficient and a significant portion of the 120B model has to stay in host RAM (offloading/swap):
How much system RAM would you consider a practical minimum to keep the pilot reliable for just one person at a time in a booth?
Any guidelines or rules-of-thumb for VRAM vs host RAM split (e.g., “X GB VRAM + Y GB RAM is okay for 120B GGUF, below that it becomes unstable or painfully slow”)?
For this use case (workstation pilot, no DGX), would you recommend:
Sticking to Ubuntu 22.04 LTS, or is 24.04 LTS also officially fine for this toolchain (drivers, CUDA, NVIDIA Container Toolkit, DGX Spark playbooks)?
Any known pitfalls or version combinations to avoid?
Finally, if you consider this setup borderline, what would you list as a “comfortable minimum” for:
VRAM (per GPU)
System RAM
for running this specific multi-agent chatbot playbook withgpt-oss-120Bfor 1–2 concurrent users?
I’m not trying to build a production multi-tenant service here; just want a stable, realistic pilot environment where people at a booth can interact with the chatbot and RAG demo without embarrassing instability or 30+ second waits per answer.
Any guidance or concrete numbers from people who’ve run this playbook (or similar 120B GGUF setups) on workstation-class hardware would be greatly appreciated.
Thanks in advance.
