Build error about "cuda-meme-v2.6"
Hi all,
I encountered many linker errors while building the project cuda-meme-v2.6 in VS2008 (CUDA 3.0).
One of the errors is as following:
Error 91 error LNK2019: unresolved external symbol _copy_model referenced in function _main meme.obj
I found that the method copy_modelmethod is declared in file memm.h as following:
extern void copy_model(
  MODEL *m1,	 /* source */
  MODEL *m2,	/* destination */
  int alength	/* length of alphabet */
But I could not find any files in the project that define that method like:
Can anyone help me if you encountered the same problem? Thanks for any kind of help from you!
Plese try to build it in Linux OS.
