I used run_dev.sh
to build the base Docker image on the host platform (x86_64).
I then built another Docker image layer on top of this base image that includes debian install of the pcl packages:
RUN apt-get update && apt-get install -y \
ros-humble-pcl-conversions \
ros-humble-pcl-msgs \
However, when then building a set of my own ros2 packages with colcon build (inside the Docker container as part of another Dockerfile image layer on top), which contain a dependency on PCL and have the corresponding build depends, find()s, and includes in package.xml/CMakeLists.txt, I get the following Cmake build error:
Imported target "MPI::MPI_C" includes non-existent path
"/opt/hpcx/ompi/lib/x86_64-linux-gnu/openmpi/include"
in its INTERFACE_INCLUDE_DIRECTORIES. Possible reasons include:
* The path was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and references files it does not
provide.
CMake Error at /usr/share/cmake-3.22/Modules/FindMPI.cmake:1264 (try_compile):
Failed to generate test project build system.
Call Stack (most recent call first):
/usr/share/cmake-3.22/Modules/FindMPI.cmake:1315 (_MPI_try_staged_settings)
/usr/share/cmake-3.22/Modules/FindMPI.cmake:1638 (_MPI_check_lang_works)
/usr/lib/x86_64-linux-gnu/cmake/vtk-9.1/VTK-vtk-module-find-packages.cmake:397 (find_package)
/usr/lib/x86_64-linux-gnu/cmake/vtk-9.1/vtk-config.cmake:150 (include)
/usr/lib/x86_64-linux-gnu/cmake/pcl/PCLConfig.cmake:270 (find_package)
/usr/lib/x86_64-linux-gnu/cmake/pcl/PCLConfig.cmake:319 (find_VTK)
/usr/lib/x86_64-linux-gnu/cmake/pcl/PCLConfig.cmake:540 (find_external_library)
CMakeLists.txt:19 (find_package)
gmake: *** [Makefile:308: cmake_check_build_system] Error 1
Notably:
- This error did not occur before the switch to Isaac-ROS 3 and the change of the ‘run_dev’ build process.
- This error does not occur when compiled for arm64 with the “Dockerfile.aarch64” and the rest being the same set of build steps.
