I’m interested in using ray tracing in a personal project and wanted to check out OptiX 8.0. My machine configuration is:
ubuntu 22.04
cuda 12.2
cmake 3.22
NVIDIA TITAN V (535.113.01)
When I try to build the SDK, one of the examples produces an error during cmake configuration:
> cd /path/to/optix8/SDK
> cmake . -Bbuild
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUDA_CUDA_LIBRARY (ADVANCED)
linked by target "optixOpticalFlow"
This isn’t a big issue, but it would be good to get that fixed – was it meant to link against ${CUDA_LIBRARIES}
like all the other examples?
The bigger problem is that, after building the examples, none of them seem to work!
> cd build && make -j
> cd bin
> ./optixConsole
> ./optixWhitted
> ./optixTriangle
after rebuilding with debug flags enabled, I get the following backtrace:
Thread 1 "optixConsole" received signal SIGSEGV, Segmentation fault.
0x0000000000000000 in ?? ()
(cuda-gdb) bt
#0 0x0000000000000000 in ?? ()
#1 0x00007fffb29dd2cd in ?? () from /lib/x86_64-linux-gnu/libnvoptix.so.1
#2 0x000055555556ffda in optixDeviceContextCreate (fromContext=0x0, options=0x7fffffffdaa0, context=0x7fffffffda90)
at /home/sam/code/optix8/include/optix_stubs.h:330
#3 0x000055555556ec93 in createContext (state=...) at /home/sam/code/optix8/SDK/optixConsole/optixConsole.cpp:675
#4 0x000055555556fa74 in main (argc=1, argv=0x7fffffffdfd8) at /home/sam/code/optix8/SDK/optixConsole/optixConsole.cpp:795
I’m looking for help figuring out how to get these examples to run.
