Build kernel __overlay__ issue
Why does the following warning appear ?
How to fix it ???
make CROSS_COMPILE=/usr/bin/aarch64-linux-gnu- ARCH=arm64 O=/home/share/NVDIA_DATA/Tegra186_git_3261_CAMERA/tegra186/build_script/…/Linux_for_Tegra/images -j20
Warning (reg_format): “reg” property in /fragment@1/overlay/spi@0 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
Warning (reg_format): “reg” property in /fragment@3/overlay/spi@0 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@1/overlay/spi@0
Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@1/overlay/spi@0
Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@3/overlay/spi@0
Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@3/overlay/spi@0
If you follow Kernel Customization in document, it should work fine. It should be triggered by additional steps. Please check if you can reproduce it on Xavier developer kit. If yes, please share the steps so that we can give it a try.
And please share your release version:
$ head  -1 /etc/nv_tegra_release
root@ubuntu:/home/user# head -1 /etc/nv_tegra_release
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t186ref, EABI: aarch64, DATE: Mon Jul 26 19:36:31 UTC 2021
overlay.log|attachment (55.8 KB)
see log
This warning should not affect the functionality of your kernel image and dtb.
Is there a way to correct this warning???
