I need to build miniPCIe driver sources on a Jetson TX1 tegra 32 bits.
uname - a gives: Linux tegra-ubuntu 3.10.96-tegra #1 SMP PREEMPT Tue May 17 16:31:40 PDT 2016 aarch64 aarch64 aarch64 GNU/Linux
The card is: Serial I/O (VL-MPEe-U2) Expansion Module | VersaLogic
Driver sources are given by the manfacturer with the following makefile (KDIR updated)
obj-m := vldrivep.o
KDIR := /usr/src/linux-headers-3.10.96-tegra/
PWD := $(shell pwd)
default:
$(MAKE) -C $(KDIR) SUBDIRS=$(PWD)
clean:
rm -f *.o *.ko modules.order Module.symvers vldrivep.mod.c
“make” command gives the following error:
root@tegra-ubuntu:/opt/ML-MPEe-U2/VersaAPI_Linux_32bit_v1.1.0/src/vldrivep# make
make -C /usr/src/linux-headers-3.10.96-tegra SUBDIRS=/opt/ML-MPEe-U2/VersaAPI_Linux_32bit_v1.1.0/src/vldrivep
make[1]: Entering directory /usr/src/linux-headers-3.10.96-tegra' LD /opt/ML-MPEe-U2/VersaAPI_Linux_32bit_v1.1.0/src/vldrivep/built-in.o CC [M] /opt/ML-MPEe-U2/VersaAPI_Linux_32bit_v1.1.0/src/vldrivep/vldrivep.o <b>gcc: error: unrecognized command line option ‘-mgeneral-regs-only’</b> make[2]: *** [/opt/ML-MPEe-U2/VersaAPI_Linux_32bit_v1.1.0/src/vldrivep/vldrivep.o] Error 1 make[1]: *** [_module_/opt/ML-MPEe-U2/VersaAPI_Linux_32bit_v1.1.0/src/vldrivep] Error 2 make[1]: Leaving directory /usr/src/linux-headers-3.10.96-tegra’
make: *** [default] Error 2
I tried to link gcc with both compilers with the same result:
/usr/bin/gcc-4.8: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, BuildID[sha1]=a42b62e7497d7f55673b6e49d8839b975579bf4c, stripped
/usr/bin/gcc-5: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, BuildID[sha1]=d869661663b3385b908c53934c4512bbe9a9a28f, stripped
Thanks for your reply.
I’ll try to cross compile my module on a virtual box Ubuntu 14.04.1 x64 but I don’t understand why I need to cross compile the kernel.
However I hope there is a way to compile my module directly on Tegra without needing to perform cross compilation.
So, I tried cross-compilation on a Linux Ubuntu x64, my target (Jetson Tx1) is still arm 32-bit. I managed to compile my module for arm 64-bit but not for arm 32-bit.
I get these errors:
root@ssa-vbox:/opt/jetson/kernel# make -j8 ARCH=arm CROSS_COMPILE=/usr/local/gcc-linaro-5.3.1-2016.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- CROSS32CC=/usr/local/gcc-linaro-5.3.1-2016.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc O=$TEGRA_KERNEL_OUT prepare
GEN /opt/jetson/build/Makefile
CHK include/generated/uapi/linux/version.h
Using /opt/jetson/kernel as source for kernel
CHK include/generated/utsrelease.h
make[2]: ‘include/generated/mach-types.h’ is up to date.
CC kernel/bounds.s
aarch64-linux-gnu-gcc: error: unrecognized argument in option ‘-mabi=apcs-gnu’
aarch64-linux-gnu-gcc: note: valid arguments to ‘-mabi=’ are: ilp32 lp64
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-mapcs’
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-mno-sched-prolog’
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-msoft-float’
/opt/jetson/kernel/./Kbuild:35: recipe for target ‘kernel/bounds.s’ failed
make[2]: *** [kernel/bounds.s] Error 1
/opt/jetson/kernel/Makefile:848: recipe for target ‘prepare0’ failed
make[1]: *** [prepare0] Error 2
Makefile:130: recipe for target ‘sub-make’ failed
make: *** [sub-make] Error 2
The “ARCH” part is for the kernel, which is 64-bit even if user space is 32-bit. You must use “ARCH=arm64” to compile a kernel or kernel modules. The “CROSS32CC” takes care of subsets of 32-bit code within the build.
In terms of compiling 32-bit user space software, you would not involve the kernel source for most cases (libraries interfacing with the kernel would be a typical exception). If you want 32-bit support in a driver under a 64-bit kernel, I believe you would need to rewrite the driver or go through extra steps when mixing it in 64-bit (I don’t know what those changes would be, but it won’t be the exact setup from simply copying the 32-bit driver to the 64-bit kernel…other changes would be mandatory).
Thanks for your answer but I don’t understand what you mean.
We have a Jetson TX1 with a 32-bit kernel. We need to compile a module for this. So as my initial post says, native Jetson 32-bit compiler gives an error when trying to compile my module source (*.c) on the TX1: 'gcc: error: unrecognized command line option ‘-mgeneral-regs-only’. This *.c is written for 32-bit.
So following your advice, I tried cross compilation on another machine with Ubuntu 64-bit without success when ARCH=arm and with success when ARCH=arm64.
Do you mean that the compiled module for arm64 will work on the 32-bit kernel Jetson TX1 ?
No Jetson TX1 kernel is 32-bit, regardless of L4T release. All kernels are 64-bit.
What differs is the root file system (user space, versus kernel space). The R23.x series is 32-bit user space, R24.1 has both 32-bit and 64-bit user space available, R24.2 is only available with 64-bit user space. The CPUs are natively 64-bit, but can operate in a 32-bit compatibility mode. So you have to differentiate between whether code is run as an ordinary application (user space), or if it is running in the kernel (such as a driver). Under R24.2 they are the same. Under most of R24.1 they are the same (to not be 64-bit you’d have to specifically use the 32-bit rootfs). Under any R23.x they differ (a case of both rootfs and kernel always differing). Some code within the kernel either runs as 32-bit for legacy reasons (such as the code from a user space 32-bit application), but will always be in compatibility mode…if user space has something which runs as 32-bit code, it switches to compatibility mode…two compilers are needed because of this.
So yes, arm64 works on a Jetson TX1 driver. So does 32-bit if 32-bit is detected and compatibility mode is configured and detected…it would be rare for 32-bit code to be used as a driver, it would be common that a user space application uses 32-bit mode.
The JTK1 is purely 32-bit. Support for JTX1 is shifting to purely 64-bit (which has performance benefits).
