I’m using the -nv-verbose option with a 40 kernels source… The build log info is clipped at 4096 bytes… so I cannot see my last kernel’s registry usage…
Pls, increment the size to almost 32Kb.
Hmm thats interesting…
Guess they thought “surely 4k is enough”!
They just need to do a clever remalloc system so that you can have a 2GB build log if you needed it…
Yep, that will be better, definitively.
