I have a question regarding my build setup, I’m currently working on Ubuntu 16.04 and Windows 10 and use CUDA 9 in both cases, Visual Studio 2015 on Windows and gcc-5 on Linux.
The project setup in both cases is done using cmake and I have the following problem.
On Linux, a complete rebuild takes about 1:30min, just building after changing a kernel takes a few seconds.
On Windows on the other hand, a rebuild takes more than 4 min and building after a kernel takes more than a minute, if not more.
Also, on Linux I only get compiler console output specific to my application, but on Windows I get thousands of warnings aimed at stuff in the cuda libraries, like
c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_20_intrinsics.h(1490): warning C4514: ‘syncthreads_or’: unreferenced inline function has been removed
1>c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_60_atomic_functions.h(394): warning C4514: ‘atomicMin_system’: unreferenced inline function has been removed
c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\thrust\system\cuda\detail\cub\device\dispatch…/…/agent/agent_radix_sort_downsweep.cuh(39): warning C4464: relative include path contains ‘…’
to name a few.
Thousands of these warnings.
I guess that I did something wrong with my configuration on Windows and that the extra long build times are linked to these warnings, but I only have found the option to limit the warnings generated by the C++ compiler in Visual Studio, but haven’t found the option for nvcc.
Anyone knows what I can do here? Thanks very much in advance! :)
