Hi Jerry,
It is my odmfuse command before.
sudo BOARDID=3668 BOARDSKU=0001 FAB=100 BOARDREV=H.0 ./odmfuse.sh --noburn -i 0x19 --auth PKC -p -k …/rsa_priv.pem jetson-xavier-nx-devkit-emmc
after I remove the “–noburn” option , it works fine , and I flash my board sucessfully.
thanks again.
Hi Jerry and jakelin.
I have the same problem. How I can generate clear (no security) massflash blob?
Im use JetPack-4.5.1 / l4t-r32.5.1, xavier-nx-devkit-emmc
ONLINE command:
sudo ./nvmassflashgen.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
error message
[ 10.1950 ] Packing sdram param for instance[14]
[ 10.1950 ] Packing sdram param for instance[15]
[ 10.1950 ]
[ 10.1951 ] Using default ramcode 0
[ 10.1951 ] Generating BPMP dtb for ramcode - 0
Error: Could not find dtc
Keep temporary directory /home/revo/xavierNX_l4t3251/Linux_for_Tegra/bootloader/8925
Error: Signing binaries failed.
hi all,
if you’re having below error, it means your host does not have Device-Tree-Compiler.
please look into your nvmassflashgen.sh
script file,
by adding below two lines to export kernel as preferred PATH.
for example,
+ KERNEL_DIR="${LDK_DIR}";
+ export PATH="${KERNEL_DIR}:${PATH}"; # preference on our DTC
Added these two lines to the end into my nvmassflashgen.sh
script file.
The same error.
hello hotspear89,
are you working with JetPack-4.5.1 release?
I’ve just verified with the offline approach, by generating Massflash image on the host machine.
for example,
$ sudo BOARDID=3668 BOARDSKU=0001 FAB=100 FUSELEVEL=fuselevel_production ./nvmassflashgen.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 5.1
Board ID(3668) version(100) sku(0001) revision()
[ 20.2398 ] Using default ramcode 0
[ 20.2398 ] Generating BPMP dtb for ramcode - 0
[ 20.3093 ] Old BPMP dtb size - 223168 bytes
[ 20.3093 ] New BPMP dtb size - 168338 bytes
[ 20.3094 ]
[ 20.3107 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 20.3115 ]
[ 20.3124 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 20.3132 ] adding BCH for mem_rcm.bct
copying nvmflash.sh ... succeeded.
copying nvaflash.sh ... succeeded.
copying emmc_bootblob_ver.txt ... succeeded.
copying qspi_bootblob_ver.txt ... succeeded.
number of images in blob are 11
*** Mass Flashing tarball mfi_jetson-xavier-nx-devkit-emmc.tbz2 is ready.
BTW,
could you please also checks that. those two lines to export kernel as preferred PATH should be default included in the line(44-45) of nvmassflashgen.sh
thanks
