Please let me know the following steps are the ones I have to go through in order to build and install Jetson Linux 35.1 real time kernel
- Download Jetson Linux 35.1 BSP and sample root file system,
- Perform the steps you suggest below to extract BSP and sample root file system assuming
Linux_for_Tegrais the build directory
sudo tar xpf JAX-TX2-Jetson_Linux_R32.1.0_aarch64.tbz2
cd Linux_for_Tegra/rootfs/
sudo tar xpf ../../JAX-TX2-Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2
cd ..
sudo ./apply_binaries.sh
sudo ./flash.sh --no-flash jetson-xxxx mmcblk0p1
- Manually Downloading and Expanding Kernel Sources as described in the
To Manually Download and Expand the Kernel Sourcessection of Kernel Customization — Jetson Linux<br/>Developer Guide 34.1 documentation - Apply RT patch and build the real-time kernel as described in the
Building the Kernelsection of Kernel Customization — Jetson Linux<br/>Developer Guide 34.1 documentation - Follow the instructions in the
Preparing to Build External Kernel Modulessection of Kernel Customization — Jetson Linux<br/>Developer Guide 34.1 documentation - Follow the instructions in the
To Build External Kernel Modulessection of Kernel Customization — Jetson Linux<br/>Developer Guide 34.1 documentation - Modify the
/boot/extlinux/extlinux.confto apply the real time kernel. How to use /boot/extlinux/extlinux.conf after jetpack 5.0 - #6 by linuxdev
