I’m trying to cross-compile code for the TegraK1 Meerkat. It has L4T release 21 revision 3, which includes CUDA 6.5. I’ve been informed that updating the CUDA runtime requires updating the kernel… so a reasonable alternative seemed to be to try a cross-compile.
For the cross-compile I’m using CUDA 7.5 on Ubuntu 14.04.
I’m trying to build the the deviceQuery executable from the sample code.
The build command I’m using is:
make TARGET_ARCH=armv7l TARGET_OS=linux SMS=32
(Specifying SMS appends “-gencode arch=compute_32,code=sm_32” to the build arguments)
However, when I try executing on the Tegra I get the following error:
cudaGetDeviceCount returned 35
→ CUDA driver version is insufficient for CUDA runtime version
Can anyone point me to documentation about how to build for previous runtime versions?
Discussion about CUDA drivers:
L4T Release Notes:
Compute versions:
