Description
I created a project with own plugins based on gridAnchor_TRT and NMS_TRT. Everything works as expected on Windows but not on Ubuntu. Surprisingly while building engine this error appears: terminate called after throwing an instance of ‘std::invalid_argument’
what(): Trying to find reduced divisor for 0
The same code works fine on windows (with the same TRT and CUDA versions).
I thought the error could be caused by one of the cuda kernels that I implemented for my plugins. But as far as I know plugin’s method enqueue() is only called while execution of context->enqueueV2()(or executeV2()) but not while building the engine.
Do you have any suggestion? Because I have no idea how to localize this error.
Environment
TensorRT Version7.0.0.11:
**GPU TypeRTX2080:
**Nvidia Driver Version440:
**CUDA Version10.2:
**CUDNN Version7.6.1:
**Operating System + VersionUbuntu 18.04:
Python Version (if applicable):
TensorFlow Version (if applicable):
**PyTorch Version (if applicable)1.2:
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
Can you please share the sample script and model file to reproduce the issue so we can help better?
Project was tested in nvcr.io/nvidia/pytorch 20.03-py3 docker container https://docs.nvidia.com/deeplearning/frameworks/pytorch-release-notes/rel_20-03.html#rel_20-03
No additional dependencies are required, except those already presented in project.
link to github repository:
https://github.com/freetown113/faceDetection.git
Thank you
It seems liballClassNMS.so lib is missing in the github repo. Getting following error:
…/bin/libil …/image
…/bin/libil: error while loading shared libraries: liballClassNMS.so: cannot open shared object file: No such file or directory
Please check in “faceDetection/Plugins/cuda/lib” it should be there. I apologize, you need to add a path to these libraries into environmental variables.
“export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/faceDetection/Plugins/cuda/lib”
Will analyze the code and update you accordingly.
But model seems to be working fine using “trtexec” command, will recommend to use “trtexec” command for now:
Using trtexec:
trtexec --onnx=model.onnx --explicitBatch --verbose --saveEngine=test.trt
[05/26/2020-10:06:09] [I] percentile: 1.97314 ms at 99%
[05/26/2020-10:06:09] [I] total compute time: 2.9944 s
&&&& PASSED TensorRT.trtexec # trtexec --onnx=model.onnx --explicitBatch --verbose --saveEngine=test.trt
Absolutely, the model by itself works fine. Nevertheless, it is useless without plugins. And the problem appears when I try to add plugins.
