Description
When I run “builder → buildCudaEngine(* network)”, the nullptr will return, what could be the reason?
I used it on ubuntu, how can I view the stack of “nvinfer1”,does it have an open source code?
I had set a logger, and print log level above “Severity::kINFO”. But I found nothing. How could I see the debug info?
I will add the detail version latter, could you please give some advice first.
Environment
TensorRT Version:
GPU Type:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
