IPA: Recompiling mol.fppized.obj: new IPA information
PGF90-F-0007-Subprogram too large to compile at this optimization level (mol.fppized.f90: 17961)
PGF90/x86 Windows 7.2-5: compilation aborted
child process exit with signal 2: D:\PGI/win32/7.2-5/bin/pgf95.EXE
specmake: *** [tonto] Error 2
Unfortunately, you can’t currently use IPA with Tonto on Win32 (win64 is fine). The problem is that “Mol.f90” is a huge file that causes the compiler, when using IPA, to allocate more than 2GB of memory. I do have a technical problem report in with our engineers about the problem and hope they can add some throttling. It will reduce the amount of optimization performed, but allow the file to compile successfully.
