Hello, sperok:
Would you please provide more details about the issue you met?
(with SDK 24.2/Jetpack 2.3, tegra_multimedia_api can be compiled without any problem.)
I want to know the SDK version, compiling error log.
@jachen - this was on a brand new TX1 with SDK 24.2/Jetpack 2.3 freshly installed doing a native (not cross) compile. I can’t recreate the exact conditions without overwriting my current working config and tight dev schedule won’t let me do that, so can’t give you any logs, sorry.
To verify - on a freshly installed system just look at tegra_multimedia_api/argus/samples/manualWhiteBalance and userAutoExposure/CMakeLists.txt files to see if ${OPENGLES_INCLUDE_DIR} is present.
Hello, sperok:
Thanks for pointing out that. We will check it internally.
As an workaround, you can install following packages first and compile should work:
