Hi:
I am trying to to build a DLL that uses CUDA to be called from VB6.
I am using Visual Studio 2005
There is no error building the DLL.
When I call the DLL from VB6 I get an error that the DLL can not be found.
If I remove *.cu files from the project, the DLL can be loaded.
I’ve tried placing all cu files in a static library and then creating a DLL that calls the CUDA routines located in the library
VB6 then calls the DLL.
Same thing happens, if any routine in the library that calls CUDA is called from the DLL, the DLL can not be loaded into VB6.
Any suggestions would be appreciated
