Building drivers for PCIe-Switch PEX8724 on Drive PX2
Hey,
I need to build a driver for the PCIe-Switch for the PEX8724 using their SDK (https://www.broadcom.com/products/pcie-switches-bridges/pcie-switches/pex8724#downloads).
The build of drivers involves the use of a PLX-provided script file (builddriver). When I run the script I get the following message:
Build: Plx8000_NT
- PLA: Ubuntu 16.04 LTS
- KER: 4.4.38-rt49-tegra
- INC: /lib/modules/4.4.38-rt49-tegra/build/include
- CPU: aarch64 (64-bit Little Endian)
- CMP: gcc
- TYP: 8000_NT Driver
- PLX: SDK v7.25
- CFG: Release
make[1]: *** /lib/modules/4.4.38-rt49-tegra/build: No such file or directory.  Stop.
/home/nvidia/Development/PEX8724/PlxSdk/Makefiles/Targets.def:43: recipe for target 'BuildDriver' failed
make: *** [BuildDriver] Error 2
The directory /lib/modules/4.4.38-rt49-tegra/build shows a broken symbolic link to /dvs/git/dirty/git-master_modular/out/embedded_aarch64-arm64-tegra_t186ref_gnu_linux_defconfig-rt_patches/kernel.
It seems that the required linux-headers are missing. How can I get them?
Thanks in advance!
Have you found the linux-headers?
I have the same problem now.
The headers are located in
/path/to/DriveWorks/VibranteSDK/vibrante-oss-src/kernel
So, first you have to use the DriveInstaller which downloads all the needed resources.
Although we are now able to build the driver for the PCIe-switch, it is not possible to load the driver, because no supported devices are found…
Dear Emme92,
did you compile the whole kernel or just compile the module?
I have little knowledge about compiling single-module, would you give me some advice, such as the environment configuration and the makefile…
Thanks a lot.
Hey,
we used this guide to compile the kernel: http://docs.nvidia.com/drive/nvvib_docs/index.html#page/NVIDIA%2520Vibrante%2520Linux%2520DPX%2520Development%2520Guide%2FSystem%2520Programming%2Fsys_programming_kernel_toolchain.html
The driver is built by a PLX-provided script file (builddriver).
