Building exe file using g++ for both c and cpp sources
I have a sample code for using Xavier’s GPIOs in C. Making exe in sample is straight forward.
g++ -O2 -Wall exampleGPIOApp.cpp jetsonGPIO.c -o exampleGPIOApp
I am using jetsonGPIO.c and jetsonGPIO.h to add into gst-dsexample lib. I am trying to modify its Makefile. But still have error. My modification is as follows and what is still wrong. The error is No Rule to make target 'jetsonGPIO.o'.
# Copyright (c) 2017-2020, NVIDIA CORPORATION.  All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
#enable this flag to use optimized dsexample plugin
#it can also be exported from command line
USE_OPTIMIZED_DSEXAMPLE?=0
CUDA_VER?=10.2
ifeq ($(CUDA_VER),)
  $(error "CUDA_VER is not set")
endif
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
CXX:= g++
ifeq ($(USE_OPTIMIZED_DSEXAMPLE),1)
  SRCS:= gstdsexample_optimized.cpp
else
  SRCS:= gstdsexample.cpp
  SRC:=jetsonGPIO.c
endif
INCS:= $(wildcard *.h)
LIB:=libnvdsgst_dsexample.so
NVDS_VERSION:=5.1
DEP:=dsexample_lib/libdsexample.a
DEP_FILES:=$(wildcard dsexample_lib/dsexample_lib.* )
DEP_FILES-=$(DEP)
CFLAGS+= -fPIC -DDS_VERSION=\"5.1.0\" \
     -I /usr/local/cuda-$(CUDA_VER)/include \
     -I ../../includes
GST_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/gst-plugins/
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
LIBS := -shared -Wl,-no-undefined \
    -L dsexample_lib -ldsexample \
    -L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart -ldl \
    -lnppc -lnppig -lnpps -lnppicc -lnppidei -pthread -lnvds_osd\
    -L$(LIB_INSTALL_DIR) -lnvdsgst_helper -lnvdsgst_meta -lnvds_meta -lnvbufsurface -lnvbufsurftransform\
    -Wl,-rpath,$(LIB_INSTALL_DIR)
OBJS:= $(SRCS:.cpp=.o)
OBJCS:= $(SRC:.c=.o)
ifeq ($(TARGET_DEVICE),aarch64)
    PKGS:= gstreamer-1.0 gstreamer-base-1.0 gstreamer-video-1.0 opencv4
else
endif
CFLAGS+=$(shell pkg-config --cflags $(PKGS))
LIBS+=$(shell pkg-config --libs $(PKGS))
all: $(LIB)
%.o: %.cpp %.c $(INCS) Makefile
    @echo $(CFLAGS)
    $(CXX) -c -o $@ $(CFLAGS) $<
$(LIB): $(OBJS) $(OBJCS) $(DEP) Makefile
    @echo $(CFLAGS)
    $(CXX) -o $@ $(OBJS) $(OBJCS) $(LIBS)
$(DEP): $(DEP_FILES)
    $(MAKE) -C dsexample_lib/
install: $(LIB)
    cp -rv $(LIB) $(GST_INSTALL_DIR)
clean:
    rm -rf $(OBJS) $(OBJCS) $(LIB)
Makefile writing is a common knowledge for c/c++ coding. Please google for the skills.
Yeah thanks I did.
Now I can make obj file for jetsonGPIO.o
Now error is those functions from jetsonGPIO.h used in gstdsexample.cpp have errors.
gstdsexample.o: In function `gst_dsexample_start(_GstBaseTransform*)':
gstdsexample.cpp:(.text+0x1b3c): undefined reference to `gpioExport(unsigned int)'
gstdsexample.cpp:(.text+0x1b50): undefined reference to `gpioSetDirection(unsigned int, unsigned int)'
gstdsexample.o: In function `gst_dsexample_stop(_GstBaseTransform*)':
gstdsexample.cpp:(.text+0x238c): undefined reference to `gpioUnexport(unsigned int)'
gstdsexample.o: In function `gst_dsexample_transform_ip(_GstBaseTransform*, _GstBuffer*)':
gstdsexample.cpp:(.text+0x2db4): undefined reference to `gpioSetValue(unsigned int, unsigned int)'
gstdsexample.cpp:(.text+0x2dd4): undefined reference to `gpioSetValue(unsigned int, unsigned int)'
collect2: error: ld returned 1 exit status
My latest Makefile is
CUDA_VER?=10.2
ifeq ($(CUDA_VER),)
endif
CXX:= g++
else
  C_SRCS:= jetsonGPIO.c
endif
NVDS_VERSION:=5.1
DEP_FILES-=$(DEP)
	 -I ../../includes
#OBJS:= $(SRCS:.cpp=.o)
OBJS:= $(SRCS:.cpp=.o) $(C_SRCS:.c=.o)
else
endif
all: $(LIB)
%.o: %.cpp $(INCS) Makefile
	@echo $(CFLAGS)
$(LIB): $(OBJS) $(DEP) Makefile
	@echo $(CFLAGS)
	$(CXX) -o $@  $(OBJS) $(LIBS)
install: $(LIB)
clean:
	rm -rf $(OBJS) $(LIB)
That is because your makefile is not correct. Please learn the makefile skills. https://makefiletutorial.com/
@Fiona.Chen thanks Fiona.
I study your tutorial. Thanks for the nice tutorial.
But what I did is correct.
Don’t know why c functions are undefined references in gstdsexample.cpp
I copied the whole codes for GPIO to gstdsexample.cpp and gstdsexample.h. Problem solved.
