I’m currently trying to build netcdf 4.1.1. We also need hdf functions, therefore
I’ve tried to compile HDF5. After playing around with the flags, we have now a working
HDF5 installation, but HDF5 libs(shared libs!) are missing!
I’ve tried various settings without any success.
If I add the flag “-shared” the pgcc creates a file a.out (running configure),
but this a.out crashes (seg fault).
a.out[19849]: segfault at 0000000000000001 rip 0000000000000001 rsp 00007fff8dbc6fa8 error 14
pgcc -shared -O conftest.c
./a.out
seg… fault
pgcc -fpic -O conftest.c
./a.out
OK
So within the configure script testing for creating shared libs is not working.
Shared Fortran libraries are not supported in the HDF5 1.6 branch, but they are supported for some platforms in the HDF5 1.8 branch. Refer to the Supported Configuration Features Summary in the 1.8.0 release notes for more details.
In 1.8.4 Patch 1, although the release notes say that Shared Fortran libs are supported with PGI on Linux, when I use the configure option “–disable-static” to ensure that I only build the shared libs, the following error occurs:
checking for mpirun… /usr/pgi/linux86-64/2010/mpi/mpich/bin/mpirun
shared libraries explicitly enabled by user
configure: WARNING: shared libraries are not supported; disabling shared Fortran libraries
configure: error: both static and shared Fortran libraries are disabled
Looks like shared Fortran libs are still not supported.
