I am trying to reflash a Jetson Xavier to get it back to it’s starting configuration. I am using Jetpack 4.3 with the CTI BSP from ConnectTech. I have gotten all of the files extracted to the Linux_for_Tegra folder and running the flash.sh script and everything seems fine until it makes the system.img file. It runs for a couple of minutes then there are hundreds of lines stating:
Cannot mkdir: No space left on device
Cannot open: No such file
The host computer building the image has over 300 GB of space available. What is going on here?
Command: sudo ./flash.sh CTI-L4T/conf/cti/xavier/rogue mmcblk0p1
Log:
tar: etc/ssl/certs/COMODO_ECC_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/COMODO_ECC_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/EE_Certification_Centre_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/EE_Certification_Centre_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/TrustCor_RootCert_CA-2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TrustCor_RootCert_CA-2.crt’: No space left on device
tar: etc/ssl/certs/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.crt’: No space left on device
tar: etc/ssl/certs/QuoVadis_Root_CA_2_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_2_G3.crt’: No space left on device
tar: etc/ssl/certs/ePKI_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/ePKI_Root_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/TrustCor_RootCert_CA-1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TrustCor_RootCert_CA-1.crt’: No space left on device
tar: etc/ssl/certs/GlobalSign_ECC_Root_CA_-_R4.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GlobalSign_ECC_Root_CA_-_R4.crt’: No space left on device
tar: etc/ssl/certs/AddTrust_External_Root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AddTrust_External_Root.crt’: No space left on device
tar: etc/ssl/certs/Security_Communication_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Security_Communication_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/Security_Communication_RootCA2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Security_Communication_RootCA2.crt’: No space left on device
tar: etc/ssl/certs/SSL.com_Root_Certification_Authority_RSA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_Root_Certification_Authority_RSA.crt’: No space left on device
tar: etc/ssl/certs/USERTrust_RSA_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/USERTrust_RSA_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/Go_Daddy_Root_Certificate_Authority_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Go_Daddy_Root_Certificate_Authority_-_G2.crt’: No space left on device
tar: etc/ssl/certs/E-Tugra_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/E-Tugra_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/IdenTrust_Commercial_Root_CA_1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/IdenTrust_Commercial_Root_CA_1.crt’: No space left on device
tar: etc/ssl/certs/Cybertrust_Global_Root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Cybertrust_Global_Root.crt’: No space left on device
tar: etc/ssl/certs/Deutsche_Telekom_Root_CA_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Deutsche_Telekom_Root_CA_2.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_Assured_ID_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/COMODO_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/COMODO_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/SSL.com_EV_Root_Certification_Authority_ECC.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_EV_Root_Certification_Authority_ECC.crt’: No space left on device
tar: etc/ssl/certs/SSL.com_Root_Certification_Authority_ECC.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_Root_Certification_Authority_ECC.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_Global_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/Starfield_Services_Root_Certificate_Authority_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Starfield_Services_Root_Certificate_Authority_-_G2.crt’: No space left on device
tar: etc/ssl/certs/Microsec_e-Szigno_Root_CA_2009.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Microsec_e-Szigno_Root_CA_2009.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_Assured_ID_Root_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_G2.crt’: No space left on device
tar: etc/ssl/certs/Baltimore_CyberTrust_Root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Baltimore_CyberTrust_Root.crt’: No space left on device
tar: etc/ssl/certs/TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.crt’: No space left on device
tar: etc/ssl/certs/OISTE_WISeKey_Global_Root_GA_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/OISTE_WISeKey_Global_Root_GA_CA.crt’: No space left on device
tar: etc/ssl/certs/GeoTrust_Universal_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GeoTrust_Universal_CA.crt’: No space left on device
tar: etc/ssl/certs/GlobalSign_Root_CA_-_R2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GlobalSign_Root_CA_-_R2.crt’: No space left on device
tar: etc/ssl/certs/OISTE_WISeKey_Global_Root_GB_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/OISTE_WISeKey_Global_Root_GB_CA.crt’: No space left on device
tar: etc/ssl/certs/LuxTrust_Global_Root_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/LuxTrust_Global_Root_2.crt’: No space left on device
tar: etc/ssl/certs/T-TeleSec_GlobalRoot_Class_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/T-TeleSec_GlobalRoot_Class_2.crt’: No space left on device
tar: etc/ssl/certs/GeoTrust_Universal_CA_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GeoTrust_Universal_CA_2.crt’: No space left on device
tar: etc/ssl/certs/Entrust_Root_Certification_Authority_-_EC1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority_-_EC1.crt’: No space left on device
tar: etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.crt’: No space left on device
tar: etc/ssl/certs/Buypass_Class_3_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Buypass_Class_3_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/GeoTrust_Primary_Certification_Authority_-_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GeoTrust_Primary_Certification_Authority_-_G3.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_Global_Root_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_G3.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_Global_Root_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_G2.crt’: No space left on device
tar: etc/ssl/certs/TeliaSonera_Root_CA_v1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TeliaSonera_Root_CA_v1.crt’: No space left on device
tar: etc/ssl/certs/Staat_der_Nederlanden_Root_CA_-_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Staat_der_Nederlanden_Root_CA_-_G3.crt’: No space left on device
tar: etc/ssl/certs/Certplus_Class_2_Primary_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certplus_Class_2_Primary_CA.crt’: No space left on device
tar: etc/ssl/certs/Staat_der_Nederlanden_Root_CA_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Staat_der_Nederlanden_Root_CA_-_G2.crt’: No space left on device
tar: etc/ssl/certs/GlobalSign_ECC_Root_CA_-_R5.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GlobalSign_ECC_Root_CA_-_R5.crt’: No space left on device
tar: etc/ssl/certs/TÜRKTRUST_Elektronik_Sertifika_Hizmet_Sağlayıcısı_H5.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TÜRKTRUST_Elektronik_Sertifika_Hizmet_Sağlayıcısı_H5.crt’: No space left on device
tar: etc/ssl/certs/Staat_der_Nederlanden_EV_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Staat_der_Nederlanden_EV_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/Atos_TrustedRoot_2011.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Atos_TrustedRoot_2011.crt’: No space left on device
tar: etc/ssl/certs/SSL.com_EV_Root_Certification_Authority_RSA_R2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_EV_Root_Certification_Authority_RSA_R2.crt’: No space left on device
tar: etc/ssl/certs/Starfield_Root_Certificate_Authority_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Starfield_Root_Certificate_Authority_-_G2.crt’: No space left on device
tar: etc/ssl/certs/Comodo_AAA_Services_root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Comodo_AAA_Services_root.crt’: No space left on device
tar: etc/ssl/certs/AffirmTrust_Networking.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AffirmTrust_Networking.crt’: No space left on device
tar: etc/ssl/certs/TWCA_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TWCA_Root_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/QuoVadis_Root_CA_1_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_1_G3.crt’: No space left on device
tar: etc/ssl/certs/Sonera_Class_2_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Sonera_Class_2_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_Trusted_Root_G4.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Trusted_Root_G4.crt’: No space left on device
tar: etc/ssl/certs/Entrust_Root_Certification_Authority_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority_-_G2.crt’: No space left on device
tar: etc/ssl/certs/Hongkong_Post_Root_CA_1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Hongkong_Post_Root_CA_1.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_High_Assurance_EV_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_High_Assurance_EV_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/thawte_Primary_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/thawte_Primary_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/thawte_Primary_Root_CA_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/thawte_Primary_Root_CA_-_G2.crt’: No space left on device
tar: etc/ssl/certs/Actalis_Authentication_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Actalis_Authentication_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/DigiCert_Assured_ID_Root_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_G3.crt’: No space left on device
tar: etc/ssl/certs/AffirmTrust_Commercial.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AffirmTrust_Commercial.crt’: No space left on device
tar: etc/ssl/certs/Network_Solutions_Certificate_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Network_Solutions_Certificate_Authority.crt’: No space left on device
tar: etc/ssl/certs/NetLock_Arany_=Class_Gold=_Főtanúsítvány.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/NetLock_Arany_=Class_Gold=_Főtanúsítvány.crt’: No space left on device
tar: etc/ssl/certs/IdenTrust_Public_Sector_Root_CA_1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/IdenTrust_Public_Sector_Root_CA_1.crt’: No space left on device
tar: etc/ssl/certs/VeriSign_Class_3_Public_Primary_Certification_Authority_-_G4.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/VeriSign_Class_3_Public_Primary_Certification_Authority_-_G4.crt’: No space left on device
tar: etc/ssl/certs/AffirmTrust_Premium_ECC.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AffirmTrust_Premium_ECC.crt’: No space left on device
tar: etc/ssl/certs/Certum_Trusted_Network_CA_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certum_Trusted_Network_CA_2.crt’: No space left on device
tar: etc/ssl/certs/SwissSign_Gold_CA_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SwissSign_Gold_CA_-_G2.crt’: No space left on device
tar: etc/ssl/certs/USERTrust_ECC_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/USERTrust_ECC_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/GDCA_TrustAUTH_R5_ROOT.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GDCA_TrustAUTH_R5_ROOT.crt’: No space left on device
tar: etc/ssl/certs/GlobalSign_Root_CA_-_R3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GlobalSign_Root_CA_-_R3.crt’: No space left on device
tar: etc/ssl/certs/QuoVadis_Root_CA_3_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_3_G3.crt’: No space left on device
tar: etc/ssl/certs/Entrust.net_Premium_2048_Secure_Server_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust.net_Premium_2048_Secure_Server_CA.crt’: No space left on device
tar: etc/ssl/certs/COMODO_RSA_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/COMODO_RSA_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/VeriSign_Universal_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/VeriSign_Universal_Root_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.crt’: No space left on device
tar: etc/ssl/certs/Entrust_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority.crt’: No space left on device
tar: etc/ssl/certs/Buypass_Class_2_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Buypass_Class_2_Root_CA.crt’: No space left on device
tar: etc/ssl/certs/Chambers_of_Commerce_Root_-_2008.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Chambers_of_Commerce_Root_-_2008.crt’: No space left on device
tar: etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_RootCA_2015.crt’: No space left on device
tar: etc/ssl/certs/Certum_Trusted_Network_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certum_Trusted_Network_CA.crt’: No space left on device
tar: etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_RootCA_2011.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_RootCA_2011.crt’: No space left on device
tar: etc/fonts/conf.d/89-tlwg-kinnari-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-kinnari-synthetic.conf’: No space left on device
tar: etc/fonts/conf.d/89-tlwg-laksaman-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-laksaman-synthetic.conf’: No space left on device
tar: etc/fonts/conf.d/89-tlwg-umpush-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-umpush-synthetic.conf’: No space left on device
tar: etc/fonts/conf.d/89-tlwg-garuda-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-garuda-synthetic.conf’: No space left on device
tar: Exiting with failure status due to previous errors
failed.
