Building Orin Nano kernel and SD image
I am attempting to add some networking features to my Orin Nano Developer Kit kernel. I am following the steps below. When trying to boot the SD card, the hardware is dumping me into an EFI shell, implying that it cannot find the requirements for a bootable SD card. Am I missing as step or something? The build host is an x86 Linux computer.
### On my laptop:
docker run -d -it -shm-size="4096m" --privileged=true --name ubuntu_20.04 ubuntu:20.04 /bin/bash
## See below where I got these
docker cp sdkmanager_*deb ubuntu_20.04:/tmp/
docker cp nvbuild.sh ubuntu_20.04:/tmp/
docker cp nvcommon_build.sh ubuntu_20.04:/tmp/
docker cp NVJETSON.config ubuntu_20.04:/tmp/
docker cp aarch64--glibc--stable-final.tar.gz ubuntu_20.04:/tmp/
docker exec -it ubuntu_20.04 /bin/bash
### Inside the docker container
mount -o remount,size=10G /dev
mkdir /opt/l4t-gcc/
pushd /opt/l4t-gcc/
tar xf /tmp/aarch64--glibc--stable-final.tar.gz
popd
apt-get update
apt-get install vim sudo build-essential bc git kmod iputils-ping libncurses5 libncurses5-dev flex bison gdisk libssl-dev /tmp/sdk*deb
useradd noc -m -s /bin/bash
visudo
# add "noc ALL=(ALL) NOPASSWD: ALL" towards bottom
su -l noc
sdkmanager --cli --query interactive
# log in with web browser
# select Jetson, Target Hardware, Jetson Orin Nano modules, Linux, JetPack 5.1.2, no detailed, no flash
sdkmanager --cli install  --logintype devzone --product Jetson --host --targetos Linux --version 5.1.2 --target JETSON_ORIN_NANO_TARGETS --flash skip
# Accept the EULAs, wait for download to complete. Select Skip once its done.
cd ~/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
# look at the actual running platform's /etc/nv_tegra_release file, you can see it is R35, REVISION: 3.1, so we want tag jetson_35.3.1
./source_sync.sh -k jetson_35.3.1 -o jetson_35.3.1
cd sources
mv /tmp/nv*sh ./
export KERNEL_OUT=/home/noc/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel_out
export kernel_out=$KERNEL_OUT
export CROSS_COMPILE_AARCH64_PATH=/opt/l4t-gcc
export CROSS_COMPILE_AARCH64=/opt/l4t-gcc/bin/aarch64-buildroot-linux-gnu-
mkdir $kernel_out
./nvbuild.sh -o $kernel_out
# make a backup of the default Kconfig
cp ./kernel/kernel-5.10/arch/arm64/configs/tegra_defconfig{,.orig}
cat /tmp/NVJETSON.config > ./kernel/kernel-5.10/arch/arm64/configs/tegra_defconfig
vi ./kernel/kernel-5.10/arch/arm64/configs/tegra_defconfig
# set the following:
# CONFIG_NET_SCH_HFSC=y
# CONFIG_NET_SCH_PRIO=y
# CONFIG_NET_SCH_SFQ=y
cd ../rootfs/
cat $kernel_out/drivers/gpu/nvgpu/nvgpu.ko | sudo tee ./usr/lib/modules/5.10.120-tegra/kernel/drivers/gpu/nvgpu/nvgpu.ko > /dev/null
cd ../kernel/dtb/
rsync -av $kernel_out/arch/arm64/boot/dts/nvidia/ ./
cd ..
cat $kernel_out/arch/arm64/boot/Image > Image
cd ../sources/kernel/kernel-5.10
sudo make ARCH=arm64 O=$kernel_out modules_install INSTALL_MOD_PATH=/home/noc/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
cd $kernel_out/../
sudo ./apply_binaries.sh -r rootfs
sudo ./tools/jetson-disk-image-creator.sh -o sdcard.img -b jetson-orin-nano-devkit -d sd
# now we have file ./sdcard.img
The downloaded files’ sources are described below:
# aarch64--glibc--stable-final.tar.gz
https://developer.nvidia.com/embedded/jetson-linux-r3541
Then go to Bootlin Toolchain gcc 9.3
# NVJETSON.config
From a running system's /proc/config.gz file
# nvbuild.sh, nvcommon_build.sh
Then go to Driver Package (BSP) Sources
Then it is buried in public_sources.tbz2 -> kernel_src.tbz2
# sdkmanager_1.9.3-10904_amd64.deb
https://developer.nvidia.com/sdk-manager
Hi ghb,
Are you using the devkit for Orin Nano?
Could your board boot up w/o issue before you add your custom network features?
Do you have standalone Ubuntu 18.04 or 20.04 as your host PC instead of using docker for SDKM?
