Hi, I am attempting to write a python codelet to hook into some of the messages within the carter_sim app with varied success.
My app is attempting to clone carter_sim but with addition of a simple pycodelet messages hook.
To do this I have copied carter.graph/.config.json into hooks.graph/.config.json and changed the app names where appropriate, I have added a new node for my pycodelet in hooks.graph.json (nothing in config as my codelet requires no configuration).
I have followed this process for kaya_sim with great success but when I run my carter python app I get the error: “no node with name “map””
Can anyone help me diagnose this issue?
Hi there,
I had similar issues a while back and you can see my attempts to get python to work on this page https://devtalk.nvidia.com/default/topic/1052351/sdk/developing-pycodelets-to-be-used-by-other-applications
My suggestions would be:
- Check that you are linked to all the correct modules in your BUILD file (remember the line to have access to the map should be "//packages/map:libmap_module.so" under "data" of your "py_binary")
- Check you are loading your map module in your Application() constructor
- Check that you are loading your config files before your graph files
- Ensure you have loaded the map graph and config for your specific map (e.g. "apps/assets/maps/carter_warehouse_p.graph.json")
Hope this helps in some way.
