Building Real-Time Video AI Applications
I am having issues with Step 4 of my coding assessment. I have updated all ‘Fixme’ portions correctly I believe, but nothing gets written to the answer text file. I would like some help/direction on this. I noticed that the video file paths cannot be accessed but I am unsure if this is causing the issue. The app uses the Dashcamnet model.
• DeepStream Version
• TensorRT Version
• The pipeline being used
• Hardware Platform (Jetson / GPU) - GPU
• DeepStream Version - 6.4
• TensorRT Version - 8.6.1
• Issue Type( questions, new requirements, bugs) - bugs
• The pipeline being used - GStreamer 1.20.3
Sample app - DashCamNet
Config File -
[property]
gpu-id=0
net-scale-factor= 0.00392156862
tlt-model-key=tlt_encode
tlt-encoded-model=/dli/task/ngc_assets/trafficcamnet_vpruned_v1.0/resnet18_trafficcamnet_pruned.etlt
labelfile-path=/dli/task/ngc_assets/trafficcamnet_vpruned_v1.0/labels.txt
int8-calib-file=/dli/task/ngc_assets/trafficcamnet_vpruned_v1.0/dashcamnet_int8.txt
input-dims=3;720;1280;0
uff-input-blob-name=input_1
batch-size= 1
process-mode= 1
model-color-format= 0
0=FP32, 1=INT8, 2=FP16 mode
network-mode= 0
num-detected-classes= 4
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
cluster-mode=0
which sample are you testing or referring to? could you share the whole log?
I am unsure what specific log you want me to share. Could you please give me more directions on what to share?
what do you mean about " ‘Fixme’ portions", " file paths"? if you need Dashcamnet sample, please refer to config_infer_primary_dashcamnet.yml
