Building Tensorflow 1.13 on Jetson Xavier
I’ve followed all the step in this post and use tag v1.13.1 to build tensorflow on TX2. However, i keep getting error of Cuda Configuration Error: Cannot find line containing ‘define NV_TENSORRT_SONAME_MAJOR’ in /usr/include/aarch64-linux-gnu/NvInfer.h at bazel build step.
tensorflow git:(6612da8951) ✗ bazel build --config=opt --config=nonccl //tensorflow/tools/pip_package:build_pip_package --incompatible_remove_native_http_archive=false --verbose_failures --cxxopt=“-D_GLIBCXX_USE_CXX11_ABI=0”
ERROR: Skipping ‘//tensorflow/tools/pip_package:build_pip_package’: error loading package ‘tensorflow/tools/pip_package’: Encountered error while reading extension file ‘build_defs.bzl’: no such package ‘@local_config_tensorrt//’: Traceback (most recent call last):
File “/home/lab421/tensorflow/third_party/tensorrt/tensorrt_configure.bzl”, line 171
_trt_lib_version(repository_ctx, trt_install_path)
File “/home/lab421/tensorflow/third_party/tensorrt/tensorrt_configure.bzl”, line 82, in _trt_lib_version
find_cuda_define(repository_ctx, trt_header_dir, “NvI…”, …)
File “/home/lab421/tensorflow/third_party/gpus/cuda_configure.bzl”, line 569, in find_cuda_define
auto_configure_fail((“Cannot find line containing '%…)))
File “/home/lab421/tensorflow/third_party/gpus/cuda_configure.bzl”, line 342, in auto_configure_fail
fail((”\n%sCuda Configuration Error:%…)))
WARNING: Target pattern parsing failed.
ERROR: error loading package ‘tensorflow/tools/pip_package’: Encountered error while reading extension file ‘build_defs.bzl’: no such package ‘@local_config_tensorrt//’: Traceback (most recent call last):
INFO: Elapsed time: 0.341s
INFO: 0 processes.
FAILED: Build did NOT complete successfully (0 packages loaded)
currently loading: tensorflow/tools/pip_package
Would really appreciate if you could help.
