Looks interesting:
http://cudatemplates.sourceforge.net/
But how am I supposed to build them?
[codebox]cudatemplates/build $ cmake …/
CMake Error at testing/CMakeLists.txt:17 (find_package):
Could not find module FindGLEW.cmake or a configuration file for package
GLEW.
Adjust CMAKE_MODULE_PATH to find FindGLEW.cmake or set GLEW_DIR to the
directory containing a CMake configuration file for GLEW. The file will
have one of the following names:
GLEWConfig.cmake
glew-config.cmake
CMake Warning at testing/CMakeLists.txt:35 (find_package):
Could not find module FindOpenCV.cmake or a configuration file for package
OpenCV.
Adjust CMAKE_MODULE_PATH to find FindOpenCV.cmake or set OpenCV_DIR to the
directory containing a CMake configuration file for OpenCV. The file will
OpenCVConfig.cmake
opencv-config.cmake
– GCC >= 4.3
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUDA_CUT_INCLUDE_DIR (ADVANCED)
used as include directory in directory /cudatemplates/testing
– Configuring incomplete, errors occurred![/codebox]
I tried blindly googling for the two missing files, but that didn’t work out for me. I found files with correct names, but they in turn gave errors.
