I’m building the kernel as described in
How to build NVIDIA Jetson Nano kernel
I can see that the MAX9296 is compiled but the driver (.ko) file is build…In which configuration file I have to add it?
To clarify, if the content is created as a module (feature “=m
”), then a “.ko
” kernel module is built. If the feature is compiled as integrated (feature “=y
”), then no module is required since the feature is always there. When setting the feature as module format or integrated format one would always use a configuration editor since not all features can be module format, and not all features can be integrated. I’m not sure which you are working on.
