Builing meaningfull DS71 docker image
DS7.1 image for X86 dGPU
Trying to setup a dev environnement by creating a “Working” container that can run the Python examples
• DeepStream Version
• TensorRT Version
Trying to build a useable image to run and dev Python DS apps.
I’m not successfull
Here is the dockerfile
FROM nvcr.io/nvidia/deepstream:7.1-samples-multiarch AS builder
RUN apt-get update
RUN apt-get install -y git
RUN apt-get install -y python3-pip
RUN pip3 install --force-reinstall numpy==1.26.0
## required for FFMPEG
RUN apt-get install -y --reinstall libflac8 libmp3lame0 libxvidcore4 ffmpeg
WORKDIR /opt/nvidia/deepstream/deepstream/sources
RUN git clone --branch v1.2.0 https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
# crucial to install Nvidia VDEC
RUN ./install.sh
RUN ./user_additional_install.sh
From the documentation
Once you have DeepStreamSDK pre-requisites and DeepStreamSDK installed on the system, navigate to <DS_ROOT>/sources/ dir which is /opt/nvidia/deepstream/deepstream/sources/ and git clone deepstream_python_apps repo here.
The latest bindings can be installed from release section. You can also build the bindings from source using the instructions in the bindings readme if needed.
I do not understand the Setup part in the document
Thanks in adavance
1.Do not use: 7.1-samples-multiarch as the base image. This image is only used for release and lacks SDK header files, which will cause pyds to fail to compile.
2.Just run the script in the image
FROM deepstream:7.1-triton-multiarch AS builder
# auto install pyds
RUN ./user_deepstream_python_apps_install.sh -b -r v1.2.0
RUN ./install.sh
