builtin_types.h
Where is builtin_types.h supposed to be coming from? I’m on Ubuntu Feisty (server), the driver module build worked, and make bombs with
make[1]: Entering directory `/home/josh/NVIDIA_CUDA_SDK/common'
g++ -m32 -W -Wall -Wimplicit -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wmultichar -Wtrigraphs -Wpointer-arith -Wcast-align -Wreturn-type -Wno-unused-function  -I. -I/usr/local/cuda/include -I./../common/inc -DUNIX -O3 -o obj/release/cutil.cpp_o -c src/cutil.cpp
src/cutil.cpp:46:27: error: builtin_types.h: No such file or directory
it’s not a path problem – there’s no file named builtin_types.h on the entire system.
The source is:
// includes, cuda
#include <builtin_types.h>
which leads me to believe there’s some cuda library I don’t have (i.e. which doesn’t come with the SDK 0.8.1 package?)
Josh
Have you installed the toolkit?
The SDK package contains just a bunch of examples and utilities.
The real compiler (nvcc) and libraries (cublas, cufft) are installed with the toolkit.
Ahhh… you see me exposed as a fool. That (and the installation of libglu1-mesa-dev) did the trick.
(I wish I knew why Ubuntu’s libglu1-mesa-dev has a dependency that sucks down the Glorious Haskell Compiler, tho :-) )
Assuming “Test PASSED” out of the demo programs means it’s working, it’s working.
Count one more Ubuntu success.
J
I come across the same problem.
I try to build a conan package from bottom to top for CUDA. When I test nvcc, it reports :
fatal error: builtin_types.h: No such file or directory
include “builtin_types.h”
so, where can I find this header file, does nvcc have something dependency I don’t know?
