I am in middle of a problem, where 8 files of around 125MB = total 1GB are generated in three minutes. Each file contains, 250,000 records to be processed. The data is generated by the SWAT program for climate model I am working on for the Earth Science Department of IUPUI.
I know some GPU programming and know its usage, I also know that GPU is based on SIMD architecture and they are not good for heavy file/IO based work.
But I am just curious, is there any way I can pull the GPU computing power to process this massive file. A normal core i3 CPU takes, around 3 mins to process a single file. for Eight file it will be 24 mins. that will make the total time 24+3= 27 mins. and I don’t want to make my user wait for 27 mins.
My idea is to load the file on the GPU, create thousands of threads, which will process the entire file from thousands of locations. Well it is kind of Single instruction to be processed on different data.
any suggestion will be helpful,
thanks,
