I want to use the fuses. I saw in the documentation that VPP_FUSE should be present in the system when burning the fuses.
What does that mean? Is it an input pin of the Jetson that should be set high by an external source to a specific voltage?
hello matanliber11,
could you please point-out which documentation you’d read about VPP_FUSE?
you might also refer to developer guide for Secureboot chapter.
thanks
NVIDIA Jetson TX2 and Jetson TX2i Fuse Specification (regarding ODM FIELD PROGRAMMABLE FUSES) :
"If these fuses are to be altered, then the first programming voltage VPP_FUSE must be present in the system at the time the fuses are to be programmed. "
hello matanliber11,
it’s a programming voltage that you should not have to configure by your own.
thanks
