Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed flashing t186ref.
hello junxing.liang,
are you having your own customize board?
please check you’re already have done pinmux configuration and you’re using the correct flash config to burn that cfg file.
thanks
It’s according to the standard. It may be broken
is this platform ever flashed before? which JetPack release image you’re working with?
thanks
Yes, 3243
could you please perform the flash.sh
manually to check again,
for example, $ sudo ./flash.sh jetson-xavier-nx-devkit mmcblk0p1
