Burned Chip on Jetson Orin Nano Dev Kit While Measuring PWM Voltage – Need Help Identifying
Hi everyone,
I’m working with the Jetson Orin Nano Developer Kit, and I ran into a problem while checking PWM voltage from the GPIO pins using a multimeter. During the measurement, one of the chips on the board burned out.
I’m trying to identify which chip it was so I can better understand what happened and possibly replace it (if feasible). Has anyone encountered a similar issue or have insight into which component might be affected in this scenario?
Any help with identifying the chip (part number, function, etc.) or advice on how to proceed would be greatly appreciated.
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the Jetson category where it’s more appropriate
Cheers,
Tom
If it is our carrier board design, then please refer to Jetson Orin Nano Developer Kit Carrier Board Reference Design Files https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/orin_nano/docs/jetson_orin_nano_devkit_carrier_board_reference_design_files_a04_20230320.zip/
If carrier board is from one of our ecosystem partners, then please reach out to them.
