Bus error when testing Tx2 USB 2.0 singal
Hello
I tried to follow “Jetson_TX2_TX2i_USB2_Tuning_Guide_Application_Note” to test usb2 signal.
But I always get Bus error when I get register XUSB_XHCI_OP_USBSTS_0
Below is log.
root@master:/sys/bus/usb/devices/usb1# cat /sys/bus/usb/devices/usb1/power/control
on
root@master:/sys/bus/usb/devices/usb1# devmem2 0x3530460 w
/dev/mem opened.
Memory mapped at address 0x7fa7a0f000.
Value at address 0x3530460 (0x7fa7a0f460): 0xE03
root@master:/sys/bus/usb/devices/usb1# devmem2 0x3530460 w 0xc03
/dev/mem opened.
Memory mapped at address 0x7fa783a000.
Value at address 0x3530460 (0x7fa783a460): 0xE03
Written 0xC03; readback 0xE03
/dev/mem opened.
Memory mapped at address 0x7f95222000.
Value at address 0x3530460 (0x7f95222460): 0x80
root@master:/sys/bus/usb/devices/usb1# devmem2 0x3530020 w
/dev/mem opened.
Memory mapped at address 0x7f9d21c000.
Value at address 0x3530020 (0x7f9d21c020): 0x805
root@master:/sys/bus/usb/devices/usb1# devmem2 0x3530020 w 0x804
/dev/mem opened.
Memory mapped at address 0x7f89135000.
Value at address 0x3530020 (0x7f89135020): 0x805
Written 0x804; readback 0x804
root@master:/sys/bus/usb/devices/usb1# devmem2 0x3530024 w
/dev/mem opened.
Memory mapped at address 0x7f8476a000.
Bus error
Do I have any error for this test?
Ho do I solve this problem?
Is the no 8bytes alignment address trigger the bus error?
Please try
root@tegra-ubuntu:/home/nvidia# devmem2 0x3530024 b
/dev/mem opened.
Memory mapped at address 0x7fb46ea000.
Value at address 0x3530024 (0x7fb46ea024): 0x1
root@tegra-ubuntu:/home/nvidia# devmem2 0x3530024 h
/dev/mem opened.
Memory mapped at address 0x7f91c05000.
Value at address 0x3530024 (0x7f91c05024): 0x1
Hi DaneLLL
Thanks for your your reply!
Issue is solved.
Root cause is 8bytes access with 4bytes alignment address.
