I am currently trying to turn a linear cpu code into a parallel code with cuda for C, I figured a good place to start would be to get nvcc to work properly on my code that does not parallelize anything. I am using an IDL script to give input and call my c code. So if I compile the code with gcc with the options
[codebox]gcc -fPIC -c filename.c -std=c99
gcc -shared -o filename.so filename.o[/codebox]
I get that there is no runtime error. Where as if I compile the code with nvcc with the command:
[codebox]nvcc -o fdtd1d_yee_mult_lnx.so --compiler-options ‘-fPIC’ -shared fdtd1d_yee_mult_lnx.c
[/codebox]
I get an error from the IDL script:
[codebox]ntw OK …
Output filename: nstxae_42.0GHz_017out.sav
Start: Tue Jul 7 11:52:28 2009
Bus error
[/codebox]
Also I have a version of the code that implements cuda in what seems a rather trivial and simple matter (so it should be hard to screw up). When I compile this code and try to run it on IDL I get the runtime error:
[codebox]Output filename: nstxae_42.0GHz_017out.sav
Start: Tue Jul 7 11:27:43 2009
% CALL_EXTERNAL: Error loading sharable executable.
Symbol: fdtd1d_yee_mult_lnx, File = fdtd1d_yee_mult_lnx.so
./fdtd1d_yee_mult_lnx.so: undefined symbol:
fdtd1d_yee_mult_lnx
% Execution halted at: FDTD1D_YEE_MULT_LNX 103
[/codebox]
fdtd1d_yee_mult_lnx.so being the shared object file that is the result of the compilation with nvcc. I was wondering if you guys had any advice as to why it would be doing this!?
