Button MCU source code
Hello, we are designing our own Carrier board for Jetson Xavier NX.
NVIDIA EVK includes EFM8SB10F2G for Power Button functionality.
Since EFM8SB10F2G is not available can you provide a source code that can be implemented on another MCU?
Do you have a recommendation for an available replacement of EFM8SB10F2G?
Thanks in advance.
Please refer to below topic. Please check with vendor for that.
Thanks for the proposal, but all variants of EFM8SB10F2G are out of stock.
Is there an option to receive a source code in case we switch to another MCU?
That needs to check with vendor.
Do you mean to check with Silicon Labs? There are no available devices from them.
Can you provide source code? Can we implement the Button MCU functionality on any MCU?
We can’t share 3rd-party source code. You can choose other MCU to implement the function.
Hi zeev1,
If you download the power button firmware from the download section, the source code is included within the archive, as well as the hex file for flashing the EFM8.
BR
