Hi where can I get a case for Jetson TK1 in EU Configure PC w/ Puget Systems Acrylic Development Enclosure for NVIDIA Jetson TK1 do not ship to Denmark :-(
Hi, i think simplest way is DIY case. Search for local laser cutter(CNC) service and order there your custom case. Use NVIDIA Jetson TK1 "sneeze guard" case by pburgess - Thingiverse (cost about 20€ + delivery) or wait for my cool custom “sneeze guard” case for Jetson and order it by your local CNC Service.
I’m currently on work for my custom case. I think i’ll get that next weekend and will post it here or on Jetson/Enclosures - eLinux.org.
thx for the replay
For laser cutting, it is worth checking out your local hackspaces. Some of them might be able to help you. http://hackerspaces.org/wiki/Denmark
Hello folks,
i found manufacturer in Germany, which can cut(laser) acrylic glas open hardware enclosure for Jetson TK1(like: http://www.thingiverse.com/thing:348473 or http://www.pugetsystems.com/parts/Case/Puget-Systems-Acrylic-Development-Enclosure-for-NVIDIA-Jetson-TK1-10406).
If 50+ peoples here will wish this article and say “i want” this enclosure, then this manufacturer will make offer by Ebay for european buyers.
Description for available versions for Jetson TK1:
Compact:
- 137mm x 137mm with rounded corner R=10mm
- upper sheet with opened 40mm FAN, GPIOs, SATA, audio jack and 4 pin power (molex) + 4 boreholes for 2.5"
- lower sheet only with 4 boreholes for mainboard spacers
- Required & not included:
- 4x M3 x 5mm or 6mm spacer male/female
- 4x M3 x 18mm spacer female/female
- 8x M3 x 5mm screws
Compact Fancy:
- upper sheet: with opened 40mm FAN(+ 52mm FAN broach), GPIOs, SATA, audio jack and 4 pin power(molex)
- middle sheet: openings for cables place for mini PCI-E full size extender (not included but for ~15€ by eBay/Ali available)
- lower sheet: place and boreholes for 2,5" HDD window for mini PCI-E card full size +plate for 3 SMA WiFi Antennas (48mm space between)
- 4x M3 x 6mm spacer male/female
- 4x M3 x 12mm spacer male/female
Compact Fancy NAS:
- lower sheet: place and boreholes for 2x2,5" HDD window for mini PCI-E card full size
Fatty NAS: WIP → not sure about this one.
- 137mm x 167mm with rounded corner R=10
- upper sheet: with opened 40mm FAN(+ 52mm FAN broach), GPIOs, SATA, audio jack and 4 pin power(molex) + window for mini PCI-E full size card
- middle sheet: openings for cables two boreholes for M2 spacers for using full size mini PCI-E card (the spacers for mini PCI-E on board need to be removed. !!! possibly loss of warranty !!!)
- lower sheet: place, holes and helper plates for 2x2,5" or 4x2,5" or 1x3,5" HDDs
- 2x M3 x 18mm spacer female/female
- 2x M3 x 25mm spacer female/female
- 10x M3 x 5mm screws
- 2x M2 x 9mm spacer
I’m next two weeks very busy with other stuff, but i think i can spend few hours in this stuff and order “Compact Fancy NAS” + “Fatty NAS” and then tell you about prices
and then make hands on photos/videos for both.
Please leave your comments here if you want some enclosure.
And as bonus photos from prototype:
Not very beatiful with this SATA cable :D.
I had no fitting SATA cable, i broken one to make 90° angle.
Hi everybody,
for being cautious, and not break my board, I have designed and printed a protective housing. Next you can check it in the photos. It has apertures for all board connectors. The size is 13.5 x 13.5 x 2.6 centimeters. With just 4 screws and 4 nuts.
If you are interested in the protective housing please feel free to send me a message. I live in Spain.
Thank you.
