We plan to use a lot of Jetson TK1 in a research project. But as we will have our own power supply, we don’t need to purchase the kit with AC Adaptors. Nvidia sells Jetson TK1 without AC adaptor? (Maybe with MOQ?).
Regards,
Regards,
I am not aware of a Jetson TX1 SKU without an AC adapter. However, there are other vendors of boards using the Tegra K1 which are usable for different purposes.
You can find a list of these boards here: [url]Jetson TK1 - eLinux.org
What power supply do you guys use? I purchased a high end ATX power supply and loads of these [url]http://www.amazon.com/Pack-PCI-6-Pin-Barrel-Gridseed/dp/B00JL38N4M[/url] pci-e to 2.1 mm barrel connectors for an off-the-shelf solution. It is very efficient and quite clean.
