Bwmgr API not supported
Jetpack 5.1.2
When I am testing the camera…
There is a considerable amount of identical messages consistently appearing in the kernel log.
I hope to resolve this issue, as it may impact the system and lead to potential crashes.
it’s a known issue, bwmgr has disabled for Orin series. you may ignore these messages.
If used for an extended period, will this message cause the system log files to grow, occupying space? I would like to disable it.
hello LeonChen,
you may following below to lower the print level, or, simply remove this line to disable the reporting.
diff --git a/drivers/platform/tegra/mc/emc_bwmgr.c b/drivers/platform/tegra/mc/emc_bwmgr.c
index cc6efb31a..f9f42d9c8 100644
--- a/drivers/platform/tegra/mc/emc_bwmgr.c
+++ b/drivers/platform/tegra/mc/emc_bwmgr.c
@@ -58,7 +58,7 @@ struct mrq_emc_dvfs_latency_response bwmgr_emc_dvfs;
 #define IS_BWMGR_SUPPORTED(x, err)                     \
 do {                                                   \
        if (x) {                                        \
-               pr_err("bwmgr API not supported");      \
+               pr_debug("bwmgr API not supported");    \
                return (err);                           \
 } while (0)
@@ -378,7 +378,7 @@ EXPORT_SYMBOL_GPL(tegra_bwmgr_register);
 void tegra_bwmgr_unregister(struct tegra_bwmgr_client *handle)
        if (bwmgr_disable) {
