I have successfully engineered and stabilized a localized, bare-metal multi-GPU AI inference cluster configured to run fully optimized, hardware-accelerated private computing pipelines completely offline. The architecture explicitly targets complete data sovereignty and zero-trust isolation, decoupling tensor tokenization and vector database indexing from public API dependencies.
Hardware Topology & Power Distribution Infrastructure:
The cluster is hosted on a repurposed open-air mining framework and scales horizontally using a segmented multi-power supply configuration:
- Primary Power Rail: Supplying an MSI z390-a Pro motherboard and a primary MSI GeForce RTX 3060 (12GB VRAM).
- Secondary/Tertiary Rails: Isolated power delivery infrastructure driving additional graphics lanes, including a PowerColor Red Devil and a Gigabyte Radeon RX 6700 XT, utilizing independent breakout blocks to manage transient voltage spikes under heavy batch inference loads.
- Host Silicon: Intel Pentium Gold G5400 CPU running a headless, CLI-only base Debian Linux environment.
Compute Stack & Driver Abstraction Overrides:
To force stable text generation and cross-backend execution across a heterogeneous array (mixed NVIDIA/AMD lanes), the pipeline leverages a custom PyTorch multi-backend stack:
- Driver Layer: Synchronized deployment of
nvidia-smibinaries mapped directly alongside AMD’s ROCm parallel runtime framework to ensure proper compute driver mapping to newly active PCIe lanes. - Model Optimization: Automated conversion routines translating Hugging Face transformer repositories into unified, single-file GGUF and ONNX formats via
convert_hf_to_gguf.pyusing explicit token/vocabulary overrides (--vocab-type hf) and wildcard matching execution. - Vectorization Matrix: Localized database storage driven by an offline ChromaDB persistent client running native
sentence-transformerstext embedding functions, achieving retrieval latencies of ~0.02s on a 11,504-element dataset.
Automated Ingestion Sentinels & DevSecOps Guards:
System automation is driven by a native Linux systemd watchdog service (va_watchdog.service) running at the multi-user target ring. The sentinel monitors localized dropzone paths via kernel tracking hooks, routes data streams through a custom Regex Data Loss Prevention (DLP) engine for real-time PII scrubbing, and executes a 6-line sliding window tokenizer loop with a 50% overlapping stride before database injection.
I am interested in getting community feedback on automated fan-curve mapping configurations via nvidia-smi binary parameters to manage localized thermal signatures across tightly spaced PCIe lanes during long-context batch operations.
