Dear all,
I’m facing some difficulties trying to compile and run a simple c++ application that uses c++ and cuda support on jetson Nano.
The app should read an image from the disk and apply a bilateral filter using opencv.
Without using cuda support everything works as expected, when I try o use cuda support I cannot compile and run.
What I’ve tried so far:
I’ve tried to disable the bilateral filter by commenting the line: “cv::cuda::bilateralFilter(src,dst,3,1,1);” The app compiles but the following error appears in the command line:
Error: OpenCV(4.1.1) /home/nvidia/host/build_opencv/nv_opencv/modules/core/include/opencv2/core/private.cuda.hpp:107: error: (-216:No CUDA support) The library is compiled without CUDA support in function ‘throw_no_cuda’
On my jetson I’ve checked if the opencv libraries with cuda support are there:
cd /usr/local/include/opencv4/opencv2/
ls -l | grep “cuda”
all the includes seem to be there…
My example code is the following:
#include <iostream>
#include <ctime>
#include <cmath>
#include "bits/time.h"
#include <opencv2/core.hpp>
#include <opencv2/highgui.hpp>
#include <opencv2/imgproc.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/core/cuda.hpp>
#include <opencv2/cudaarithm.hpp>
#include <opencv2/cudaimgproc.hpp>
#define TestCUDA true
using namespace std;
int main() {
std::clock_t begin = std::clock();
cout << "Test....\n";
try {
cv::String filename = "animal.jpg";
cv::Mat srcHost = cv::imread(filename, cv::IMREAD_GRAYSCALE);
for(int i=0; i<1000; i++) {
if(TestCUDA) {
cv::cuda::GpuMat dst, src;
src.upload(srcHost);
//cv::cuda::threshold(src,dst,128.0,255.0, CV_THRESH_BINARY);
cv::Mat resultHost;
dst.download(resultHost);
} else {
cv::Mat dst;
cv::bilateralFilter(srcHost,dst,3,1,1);
// cv::imshow("Result",dst);
// cv::waitKey();
} catch(const cv::Exception& ex) {
std::cout << "Error: " << ex.what() << std::endl;
std::clock_t end = std::clock();
std::cout << double(end-begin) / CLOCKS_PER_SEC << std::endl;
In my development environment I’m using nsight eclipse 10.2 on my host computer and here are the build settings that I find relevant:
I’ve installed opencv on my jetson with cuda support using this “popular” instruction from Jetson Hacks:
It is possible that I’m missing something simple… I appreciate your help!
Regards :)
