C++ Bit Fields
Does the CUDA compiler support Bit Fields now ?
Bit Fields allow us to compress data into the minimum of bits,
with precission read/write to sigle bits in a byte, or below the byte level, preferably in structs.
Example: This pack structure occupies only 4 bit of memory:
eg four values, where each can contain only 0 or 1:
struct {
unsigned int f1:1;
unsigned int f2:1;
unsigned int f3:1;
unsigned int f4:1;
} pack;
References:
http://forums.nvidia.com/index.php?showtop…9&hl=bit+fields
http://msdn2.microsoft.com/en-us/library/e…dbe(VS.71).aspx
I don’t recall anything in the CUDA 1.1 release notes particularly mentioning bit fields. Why don’t you try it and find out?
error: duplicate member `__dummy’ !
Thus I conclude that Bit Fields are not supported in Cuda.
