If I include <process.h> header and try to compile (PGI compiler 17.4, x64) a test C program on Windows I get:
PGC-W-0114-More than one type specified (C:/Program Files (x86)/Windows Kits/10/Include/10.0.15063.0/um\commdlg.h: 729)
PGC-W-0143-Useless typedef declaration (no declarators present) (C:/Program Files (x86)/Windows Kits/10/Include/10.0.15063.0/um\commdlg.h: 729)
PGC-W-0043-Redefinition of symbol, LPUINT (C:/Program Files (x86)/Windows Kits/10/Include/10.0.15063.0/um\imm.h: 45)
PGC-S-0040-Illegal use of symbol, __vcrt_bool (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 40)
PGC-W-0156-Type not specified, 'int' assumed (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 40)
PGC-S-0040-Illegal use of symbol, __vcrt_bool (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 41)
PGC-W-0156-Type not specified, 'int' assumed (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 41)
PGC-S-0040-Illegal use of symbol, __vcrt_bool (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 42)
PGC-W-0156-Type not specified, 'int' assumed (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 42)
PGC-S-0040-Illegal use of symbol, __vcrt_bool (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 43)
PGC-W-0156-Type not specified, 'int' assumed (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 43)
PGC-S-0040-Illegal use of symbol, __vcrt_bool (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 44)
PGC-W-0156-Type not specified, 'int' assumed (C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/include\vcruntime_startup.h: 44)
PGC/x86-64 Windows 17.4-0: compilation completed with severe errors
test2.o : error LNK2005: IN6_ADDR_EQUAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_UNSPECIFIED already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_LOOPBACK already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_MULTICAST already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_EUI64 already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_SUBNET_ROUTER_ANYCAST already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_SUBNET_RESERVED_ANYCAST already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_ANYCAST already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_LINKLOCAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_SITELOCAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_GLOBAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_V4MAPPED already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_V4COMPAT already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_V4TRANSLATED already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_MC_NODELOCAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_MC_LINKLOCAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_MC_SITELOCAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_MC_ORGLOCAL already defined in test1.o
test2.o : error LNK2005: IN6_IS_ADDR_MC_GLOBAL already defined in test1.o
test2.o : error LNK2005: IN6_SET_ADDR_UNSPECIFIED already defined in test1.o
test2.o : error LNK2005: IN6_SET_ADDR_LOOPBACK already defined in test1.o
test2.o : error LNK2005: IN6ADDR_SETANY already defined in test1.o
test2.o : error LNK2005: IN6ADDR_SETLOOPBACK already defined in test1.o
test2.o : error LNK2005: IN6ADDR_ISANY already defined in test1.o
test2.o : error LNK2005: IN6ADDR_ISLOOPBACK already defined in test1.o
test2.o : error LNK2005: IN6ADDR_ISEQUAL already defined in test1.o
test2.o : error LNK2005: IN6ADDR_ISUNSPECIFIED already defined in test1.o
test2.o : error LNK2005: gai_strerrorA already defined in test1.o
test2.o : error LNK2005: gai_strerrorW already defined in test1.o
test2.o : error LNK2005: setipv4sourcefilter already defined in test1.o
test2.o : error LNK2005: getipv4sourcefilter already defined in test1.o
test2.o : error LNK2005: setsourcefilter already defined in test1.o
test2.o : error LNK2005: getsourcefilter already defined in test1.o
test2.o : error LNK2005: idealsendbacklogquery already defined in test1.o
test2.o : error LNK2005: idealsendbacklognotify already defined in test1.o
test.dll : fatal error LNK1169: one or more multiply defined symbols found
if I remove the
ws2tcpip.h
header from both the example files it compiles fine.
Once that is done, install the compilers again. When running the compilers, you can use the DOS Command Window or the Bash Command Window to execute your commands, and the environment
in the Command window will know where the compilers are.
17.4 Windows release will only work with Windows 2015.
