C++ Example for NV accelerated video encoding in GStreamer
I have a data source generating raw frames with physical capture timestamps in C++. I’d like to feed the data into a pipeline to encode it to h265/mp4 files, ideally preserving the timestamps for each frame in the resulting videos.
A working pipeline fitting my needs is (replacing my own source with videotestsrc):
gst-launch-1.0 videotestsrc pattern=ball ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=(string)NV12, width=(int)2592, height=(int)1944, framerate=(fraction)10/1’ ! nvv4l2h265enc ! h265parse ! splitmuxsink location=output%02d.mp4 max-size-time=1000000000 -e
But when I tried to implement my own appsrc in C++ the pipeline keeps crashing with minimum error message.
Is there any working example of C++ code for such a use case?
The video sdk samples are here.
I’m not suggesting any are an exact replica of your gstreamer pipeline. Merely pointing it out for reference. I also note that gstreamer is open source.
This is a working solution.
The issues I encountered:
  1. crashes with missing PTS: after adding probes to each pad along the pipeline and checking if the PTS is valid, I find some frames have duplicated PTS from my appsrc.
  2. GRAY8 to NV12 conversion with nvvidconv: after checking the source code of nvvidconv I find this conversion is not supported.
gchararray FormatLocation(GstElement* splitmux, guint, gpointer) {
    gchararray location;
    g_object_get(G_OBJECT(splitmux), "location", &location, nullptr);
    std::string location_str =
        absl::StrCat(location, "_",
                     std::chrono::duration_cast<std::chrono::microseconds>(
                         std::chrono::system_clock::now().time_since_epoch())
                         .count(),
                     ".mp4");
    return g_strdup(location_str.c_str());
class Encoder {
   public:
    explicit Encoder(const std::string& format, int width, int height,
                     int framerate_numerator, int framerate_denominator,
                     const std::string& filesink_location,
                     const std::string& nvvidconv_output_format) {
        pipeline_ = gst_pipeline_new("pipeline");
        appsrc_ = gst_element_factory_make("appsrc", "appsrc");
        g_object_set(G_OBJECT(appsrc_), "format", GST_FORMAT_TIME, nullptr);
        gst_app_src_set_stream_type(GST_APP_SRC(appsrc_),
                                    GST_APP_STREAM_TYPE_STREAM);
        gst_app_src_set_caps(
            gst_caps_new_simple("video/x-raw", "format", G_TYPE_STRING,
                                format.c_str(), "width", G_TYPE_INT, width,
                                "height", G_TYPE_INT, height, "framerate",
                                GST_TYPE_FRACTION, framerate_numerator,
                                framerate_denominator, nullptr));
        // To extract the subtitle:
        // ffmpeg -i output00.mp4 -map 0:s:0 subs.srt
        // To view PTS:
        // ffmpeg -i output00.mp4 -vf "showinfo" -f null -
        subtitle_appsrc_ =
            gst_element_factory_make("appsrc", "subtitle_appsrc");
        g_object_set(G_OBJECT(subtitle_appsrc_), "format", GST_FORMAT_TIME,
                     nullptr);
        gst_app_src_set_stream_type(GST_APP_SRC(subtitle_appsrc_),
            gst_caps_new_simple("text/x-raw", "format", G_TYPE_STRING, "utf8",
                                nullptr));
        auto* nvvidconv = gst_element_factory_make("nvvidconv", "nvvidconv");
        auto* nvv4l2h265enc =
            gst_element_factory_make("nvv4l2h265enc", "nvv4l2h265enc");
        g_object_set(G_OBJECT(nvv4l2h265enc), "maxperf-enable", TRUE,
                     "control-rate", 0, "bitrate", 1'000'000, "peak-bitrate",
                     8'000'000, nullptr);
        auto* h265parse = gst_element_factory_make("h265parse", "h265parse");
        auto* mp4mux = gst_element_factory_make("mp4mux", "mp4mux");
        g_object_set(G_OBJECT(mp4mux), "fragment-duration", 1000, nullptr);
        auto* splitmuxsink =
            gst_element_factory_make("splitmuxsink", "splitmuxsink");
        g_object_set(G_OBJECT(splitmuxsink), "location",
                     filesink_location.c_str(), "max-size-bytes", 100'000'000,
                     "muxer", mp4mux, "max-files", 3, nullptr);
        g_signal_connect(splitmuxsink, "format-location",
                         G_CALLBACK(FormatLocation), nullptr);
        gst_bin_add_many(GST_BIN(pipeline_), appsrc_, nvvidconv, nvv4l2h265enc,
                         h265parse, subtitle_appsrc_, splitmuxsink, nullptr);
        CHECK(gst_element_link_filtered(
            gst_caps_from_string(
                absl::StrCat("video/x-raw(memory:NVMM),", "format=", "(string)",
                             nvvidconv_output_format.c_str(), ",width=",
                             "(int)", width, ",height=", "(int)", height)
                    .c_str())));
        CHECK(gst_element_link(appsrc_, nvvidconv));
        CHECK(gst_element_link_pads(subtitle_appsrc_, nullptr, splitmuxsink,
                                    "subtitle_%u"));
        CHECK(gst_element_link(nvv4l2h265enc, h265parse));
        CHECK(gst_element_link_pads(h265parse, "src", splitmuxsink, "video"));
        CHECK(gst_element_set_state(pipeline_, GST_STATE_PLAYING) !=
              GST_STATE_CHANGE_FAILURE);
    void Push(GstBuffer* buffer, GstBuffer* subtitle_buffer = nullptr) {
        int64_t pts = GST_BUFFER_PTS(buffer);
        if (pts < last_pts_) {
            LOG(ERROR) << "Out of order " << pts;
            gst_buffer_unref(buffer);
        } else if (pts == last_pts_) {
            LOG(WARNING) << "Same as the last one " << pts;
        } else {
            last_pts_ = pts;
            gst_app_src_push_buffer(GST_APP_SRC(appsrc_), buffer);
            if (subtitle_buffer) {
                gst_app_src_push_buffer(GST_APP_SRC(subtitle_appsrc_),
                                        subtitle_buffer);
    ~Encoder() {
        gst_app_src_end_of_stream(GST_APP_SRC(appsrc_));
        gst_app_src_end_of_stream(GST_APP_SRC(subtitle_appsrc_));
        /* Wait until error or EOS */
        auto* bus = gst_element_get_bus(pipeline_);
        auto* msg = gst_bus_timed_pop_filtered(
            bus, GST_CLOCK_TIME_NONE,
            static_cast<GstMessageType>(GST_MESSAGE_ERROR | GST_MESSAGE_EOS));
        if (GST_MESSAGE_TYPE(msg) == GST_MESSAGE_ERROR) {
            g_error(
                "An error occurred! Re-run with the GST_DEBUG=*:WARN "
                "environment "
                "variable set for more details.");
        gst_message_unref(msg);
        gst_object_unref(bus);
        gst_element_set_state(pipeline_, GST_STATE_NULL);
        gst_object_unref(pipeline_);
   private:
    GstElement* appsrc_;
    GstElement* subtitle_appsrc_;
    GstElement* pipeline_;
    int64_t last_pts_ = 0;
