C++ libargus - error messages dmesg
I get this error while streaming with C++ libargus application. Do you think it is more related to software or hardware? I think it happens most of the time when closing one stream and starting another with different settings.
[ 418.969055] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 418.969060] name=[nvhost_sync:36], current value=9441 waiting value=9448
[ 418.969068] ---- mlocks ----
[ 418.969110] ---- syncpts ----
[ 418.969119] id 2 (disp_a) min 10220 max 10220 refs 1 (previous client : )
[ 418.969124] id 3 (disp_b) min 1322 max 1322 refs 1 (previous client : )
[ 418.969129] id 4 (disp_c) min 1 max 1 refs 1 (previous client : )
[ 418.969133] id 5 (disp_d) min 10221 max 10221 refs 1 (previous client : )
[ 418.969137] id 6 (disp_e) min 1490 max 1490 refs 1 (previous client : )
[ 418.969141] id 7 (disp_f) min 2 max 2 refs 1 (previous client : )
[ 418.969146] id 8 (vblank0) min 25028 max -2 refs 1 (previous client : )
[ 418.969152] id 11 (vblank1) min 25007 max -4 refs 1 (previous client : )
[ 418.969160] id 17 (gv11b_511) min 4 max 4 refs 1 (previous client : )
[ 418.969164] id 18 (gv11b_510) min 2610 max 2610 refs 1 (previous client : )
[ 418.969168] id 19 (gv11b_509) min 4 max 4 refs 1 (previous client : )
[ 418.969172] id 20 (gv11b_508) min 2912 max 2912 refs 1 (previous client : )
[ 418.969177] id 21 (15340000.vic_MSIServer_0) min 64590 max 64590 refs 1 (previous client : 15340000.vic_MSIServer_0)
[ 418.969182] id 22 (progress) min 40411 max 4 refs 1 (previous client : progress)
[ 418.969186] id 23 (stats_progress) min 146549 max 0 refs 1 (previous client : stats_progress)
[ 418.969191] id 25 (gv11b_507_user) min 131072 max 131072 refs 1 (previous client : gv11b_507_user)
[ 418.969197] id 29 (gv11b_506_user) min 131109 max 131088 refs 1 (previous client : gv11b_506_user)
[ 418.969202] id 31 (gv11b_505_user) min 131072 max 131072 refs 1 (previous client : gv11b_505_user)
[ 418.969207] id 33 (gv11b_504_user) min 131072 max 131072 refs 1 (previous client : gv11b_504_user)
[ 418.969212] id 35 (gv11b_503_user) min 131072 max 131072 refs 1 (previous client : gv11b_503_user)
[ 418.969228] id 36 (progress) min 9441 max 0 refs 1 (previous client : progress)
[ 418.969237] tegra194-vi5 15c10000.vi: vi capture get status failed
[ 418.969239] id 39 (gv11b_493) min 11 max 11 refs 1 (previous client : gv11b_502)
[ 418.969245] id 40 (gv11b_494) min 9 max 9 refs 1 (previous client : gv11b_501)
[ 418.969250] id 41 (gv11b_497) min 4 max 4 refs 1 (previous client : gv11b_495)
[ 418.969254] id 42 (gv11b_497_user) min 921561 max 921561 refs 1 (previous client : gv11b_495_user)
[ 418.969259] id 44 (gv11b_496_user) min 921570 max 921570 refs 1 (previous client : gv11b_501_user)
[ 418.969264] id 46 (gv11b_502_user) min 917504 max 917504 refs 1 (previous client : gv11b_502_user)
[ 418.969269] id 48 (gv11b_501_user) min 917504 max 917504 refs 1 (previous client : gv11b_496_user)
[ 418.969274] id 50 (gv11b_495_user) min 917504 max 917504 refs 1 (previous client : gv11b_497_user)
[ 418.969278] id 51 (gv11b_498) min 9 max 9 refs 1 (previous client : gv11b_495)
[ 418.969282] id 52 (gv11b_499) min 9 max 9 refs 1 (previous client : gv11b_494)
[ 418.969286] id 53 (gv11b_500) min 9 max 9 refs 1 (previous client : gv11b_493)
[ 418.969665] ---- channels ----
[ 418.969696]
channel 2 - 15820000.se
[ 418.969701] NvHost basic channel registers:
[ 418.969709] CMDFIFO_STAT_0: 00002040
[ 418.969714] CMDFIFO_RDATA_0: 08400120
[ 418.969720] CMDP_OFFSET_0: 00000000
[ 418.969725] CMDP_CLASS_0: 00000000
[ 418.969730] CHANNELSTAT_0: 00000000
[ 418.969734] The CDMA sync queue is empty.
[ 418.969744]
channel 3 - 15830000.se
[ 418.969748] NvHost basic channel registers:
[ 418.969753] CMDFIFO_STAT_0: 00002040
[ 418.969758] CMDFIFO_RDATA_0: 10184000
[ 418.969764] CMDP_OFFSET_0: 00000000
[ 418.969769] CMDP_CLASS_0: 00000000
[ 418.969773] CHANNELSTAT_0: 00000000
[ 418.969777] The CDMA sync queue is empty.
[ 418.969787]
channel 4 - 15840000.se
[ 418.969790] NvHost basic channel registers:
[ 418.969796] CMDFIFO_STAT_0: 00002040
[ 418.969801] CMDFIFO_RDATA_0: 44509403
[ 418.969806] CMDP_OFFSET_0: 00000000
[ 418.969811] CMDP_CLASS_0: 00000000
[ 418.969816] CHANNELSTAT_0: 00000000
[ 418.969820] The CDMA sync queue is empty.
[ 418.969831]
---- host general irq ----
[ 418.969837] sync_intc0mask = 0x00000001
[ 418.969842] sync_intmask = 0x50000003
[ 418.969846]
---- host syncpt irq mask ----
[ 418.969850]
---- host syncpt irq status ----
[ 418.969857] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 418.969862] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 418.969867] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 418.969873] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 418.969878] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 418.969884] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 418.969889] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 418.969894] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 418.969900] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 418.969905] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 418.969910] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 418.969916] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 418.969922] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 418.969927] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 418.969932] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 418.969937] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 418.969943] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 418.969948] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 418.969953] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 418.969959] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 418.969964] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 418.969969] syncpt_thresh_cpu0_int_status(21) = 0x00000000
Best regards,
jb
What’s the different setting?
Suppose it could be the sensor configure problem.
We will investigate further and I come back to you!
