I need to do find orthogonal basis of random weights using GPU in a certain Machine learning Algoithm . Is there any C++/C library that supports this function ?
Is there a library available for use on CPUs that provides the required / desired functionality?
I don’t know ! I was using Matlab to do that. I was reading that it can be found using SVD and rank of matrix. So if you could tell me a good library for SVD and rank, then I could work it out .
I was was under the impression that MATLAB offers quite extensive GPU support, have you checked into that? In fact, checking the MATLAB online documentation, I see “svd” listed under GPU-accelerated functionality, although as someone who has never used MATLAB, I cannot tell whether that refers to the functionality you need: [url]http://www.mathworks.com/help/distcomp/run-built-in-functions-on-a-gpu.html[/url]
For machine learning, NVIDIA ships the CUDNN library. I have no idea what functionality it comprises, as I have never used it, but it wouldn’t hurt to check: [url]https://developer.nvidia.com/cuDNN[/url]
Sorry about the confusion, I need C++/C library for that . I have updated question !
