I have a very irritating issue while running a C++ application. I am using the pgcpp compiler on the Interix subsystem of Windows Xp. My problem is essentially described here:
I have a class definition in a header file. This header file is included in one source file. This class has two constructors and is basically used to implement a logger. The first constructor takes ostream *out as an argument, while the second overloaded constructor takes a filename and a default boolean value of false. The objective of this second constructor is to get a stream for the filename that we are passing and to start logging messages to it. The code in the constructors is as follows:
MessageLogger::MessageLogger (std::ostream *out)
: p_out (out), p_ofstream (0), p_indent_level (0)
if (p_out)
(*p_out) << “Started logging messages” << endl;
MessageLogger::MessageLogger (char const *filename, bool append_to_file)
: p_out (0), p_ofstream (0), p_indent_level (0)
if (append_to_file)
p_ofstream = new std::ofstream (filename, ios::app);
else
p_ofstream = new std::ofstream (filename);
p_out = p_ofstream;
if (p_out)
Where the declarations of p_out and p_ofstream are as follows:
std::ostream *p_out;
std::ofstream *p_ofstream;
unsigned int p_indent_level;
All the three mentioned above are private members. The instantiation of the MessageLogger class is done as:
MessageLogger logger (“filename”); Please note that append_to_file has a default value of false. PGDBG is also misbehaving. I am inexplicably able to step in when the control is at p_ofstream = new std::ofstream (filename); and it steps into a random location and then the application crashes.
Also, when I try to see either of Mixed or Disassembly code in PGDBG, the debugger crashes with the message:
jpgdbg parse: Newline must follow cmd in 'eleq “0” struct MessageLogger *MessageLogger::MessageLogger(struct basic_ostream *out); (TranslatorGeneric.cpp
jpgdbg jpgdbgFileSelector processMsg: Warning unexpected msg token 5
jpgdbg parse: Newline must follow cmd in 'eleq “1” struct MessageLogger *MessageLogger::MessageLogger(char *filename, unsigned char append_to_file); (Tr
anslatorGeneric.cpp)
I am unable to reproduce this in a sample program where I did the exact same thing as above but everything works fine. Can someone please explain what is happening and if there is a fix to this?
Thanks,
Aditya.
