I have a mixed Fortran and C code. I have to add C to Fortran as a separate project and link it an external lib.
The system works fine when both are compiled as x64. But the C lib cannot be linked when I compile them with the Win32 option. An error "cannot open input file ‘…/ …/xxc.lib’. The compiling of the c lib with Win32 shows no error.
Hi Jia-olemiss,
It may be that the relative path used to locate xxc.lib for x64 is different than what is required to locate it for Win32. This is because Microsoft chose a different folder hierarchy for x64 output folders than it uses for Win32.
For example, a VC++ project called VCTest will have the following
directory structure by default:
VCTest (.sln is here)
Debug
x64
Debug
VCTest (.vcxproj is here)
Debug
x64
Debug
The Win32 build outputs are in the Debug directories; the x64 outputs
are in the x64/Debug directories.
Contrast this with how PVF lays out a project:
PVFTest (.sln is here)
PVFTest (.pvfproj is here)
Win32
Debug
x64
Debug
- Mat
Hi Mat,
Two different paths were used for linking each of the lib files. The error
“LINK : fatal error LNK1181: cannot open input file '…/…” shows only for the Win32 lib.
Instead of using a relative path, try using the absolute path name to the library.
- Mat
Mat,
The result also has error:
LINK : fatal error LNK1104: cannot open file '://C:\Users…
