I am using PGF95 version 7.1-3 under Windows. Please look at the following sample code:
integer(4) function WinMain (hInstance, hPrevInstance, lpszCmdLine, nCmdShow)
!DEC$ ATTRIBUTES STDCALL,ALIAS : '_WinMain@16' :: WinMain
use dfwin
integer(4) hInstance, hPrevInstance, lpszCmdLine, nCmdShow, iret
integer(4) imax, n, incx, isamax, k
real(4) x(10)
character(len=50) s1
x = [1, 8, 5, 7, 9, 2, 4, 6, 8, 0]
n = 10; incx = 1
imax = isamax(n, x, incx)
write(s1,'(a,f2.0)') 'Maximum absolute value is: ', x(imax)
! s1 = trim(s1)//char(0)
iret = MessageBox(NULL, s1, "Test"C, IOR(MB_ICONHAND,MB_OK))
WinMain = 0
end
This is a simple windows application which calls BLAS function ISAMAX to compute a index of a real vector element with maximum absolute value. The code can be compiled successfully using the following command:
pgf95 -winapp -fastsse -defaultlib:user32 -defaultlib:shell32 -lblas my_sample.f90
Here are my questions:
(1) Windows API function “MessageBox” requires the string “s1” to be C-type (i.e., has a C null character). However, when I uncomment the line “s1 = trim(s1)//char(0)” in the above code, the compiler issued the following error messages:
my_sample.f90:
PGF90-S-0075-Subscript, substring, or argument illegal in this context for 'constant' (my_sample.f90: 18)
PGF90-S-0146-Expression must be character type (my_sample.f90: 18)
I have no idea why the sentence “s1 = trim(s1)//char(0)” didn’t work here, as the similar code can be compiled in the following console program without any problem:
program test
real(4) x(10)
n = 10; incx = 1
write(*,*) s1
end
(2) Assume that I want to use the optimized library ACML instead of BLAS and LAPACK libraries. The following command didn’t work,
pgf95 -winapp -fastsse -defaultlib:user32 -defaultlib:shell32 -lacml my_sample.f90
and the error message was:
my_sample.obj : error LNK2019: unresolved external symbol _ISAMAX@12 referenced in function _winmain@16
After checking from ACML manual, I realized that -Munix option has to be used when the code is linked with ACML. But I got another error when -Munix was added to the command line:
pgf95 -winapp -fastsse -Munix -defaultlib:user32 -defaultlib:shell32 -lacml my_sample.f90
my_sample.f90:
f90win32main.obj : error LNK2019: unresolved external symbol _winmain referenced in function _WinMain@16
I guess that is because -Munix changed the default calling convention to UNIX type which is not compatible with Windows API libraries. I wondering if there is an alternative way to use ACML for Windows applications.
