C style preprocessor directives in Fortran90 using pgf90
Hi All,
I have no idea which switch I have to use in order to compile code as shown below. I need a pgf90 equivalent to intel’s
-fpp -DSELFE
#IFDEF SELFE
use elfe_glbl, only : MNE => nea
#ENDIF SELFE
If I use pgf90 the result is as follow also using -DSELFE
pgf90 -c -DSELFE datapl.f90
PGF90-S-0021-Label field of continuation line is not blank (datapl.f90: 9)
PGF90-S-0021-Label field of continuation line is not blank (datapl.f90: 31)
PGF90-F-0004-Unable to open MODULE file elfe_glbl.mod (datapl.f90: 10)
PGF90/x86-64 Linux 10.3-0: compilation aborted
thanks for any suggestions
Hi surfjunky,
“-Mpreprocess” or change your suffix to “.F90”.
  • Mat
