Just purchased a Tesla C1060. I’m installing it into a Lenovo 9965 quad-core machine. I have the
power connected using two 6-pin connectors. I get the green LED on both connections.
I had to use a PCI video card because when I use the integrated video with the C1060 installed
there is no video. Install the PCI card and video works with the C1060 installed.
Problem is the machine/OS will not see the card. I’ve tried a Redhat 5.2 (64-bit) load and a windows
XP (32-bit) load.
What is the PCI video card, and what drivers have you installed for the Tesla. At the very least, you should see the Telsa in the output of lspci, something like:
[codebox]david@quadro:~$ sudo lspci -tv
-[0000:00]-±00.0 Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller
